04-07-2014, 04:18 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Kamloops BC. Canada
| RC4wd new Warn winch problems
Hello everyone, I recently purchased RC4wd's new Warn winch and wired controller and hooked it up. For the first day it worked awesome, but now it is causing my rig to brown out bad, also it only wants to retract the line and does not want to extend the line. I am using my aux channel set in 3 position on my RX. I am running a Holmes Hobbies BR-XL waterproof ESC with a Holmes Hobbies Torquemaster Pro 27T controlled by a Spektrum DX3C and a 301 reciever. when I disconnect the winch controller everything works great, but as soon as I connect the winch controller it makes my rig run like it has a dead battery. So confused |
04-07-2014, 06:08 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
You should wire the power of the winch controller directly to your battery plug or get an external BEC and you could power your 9reliever that way. Either way would work fine, put signal still needs to get to receiver so the BEC is probably easiest. The internal BEC in the esc isn't enough amperage to handle all the stuff, plus spek recovered are very sensitive when it comes to voltage. |
04-12-2014, 01:55 AM | #3 |
Pebble Pounder Join Date: Jun 2008 Location: Carmichael
Contact heyok for his bec. I just picked 2 up and man what a difference.
04-12-2014, 07:31 AM | #4 |
Pebble Pounder Join Date: Sep 2013 Location: Fall River
Stock winch controller is GARBAGE.... Once I got a hey ok 3p it worked perfectly ... But rc4wd don't tell people this haha Sent from my iPhone using Tapatalk |
04-12-2014, 08:01 AM | #5 |
I am already using a bec to run my Hitec 8380 servo.
04-12-2014, 08:02 AM | #6 |
So the hey ok winch controller is better than the new wired one from rc4wd.
04-12-2014, 08:12 AM | #7 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: RC4wd new Warn winch problems
Big time!
04-12-2014, 08:14 AM | #8 |
04-12-2014, 08:24 AM | #9 |
@heyok. How do I get one of your winch controllers?
04-12-2014, 08:35 AM | #10 |
Newbie Join Date: Apr 2012 Location: Perry
I see that you Guys are talkin' the "Wired Controller". Would this issue also effect the Wireless/Remote, as my friend just p/up the Winch, cntrlr & remote ?? Thanks, plus we will check out the Hey Ok.
04-12-2014, 08:36 AM | #11 |
04-14-2014, 12:15 PM | #12 |
| Re: RC4wd new Warn winch problems |
10-05-2014, 08:18 PM | #13 |
Newbie Join Date: Feb 2014 Location: Colchester
Just wondering if you got the problem solved with the heyok controller. I'm wanting to run duel winches on mine. I don't want to get two wireless ones. Would like to get two wired ones. My remote has two 3 position switchs.
10-05-2014, 08:26 PM | #14 |
Yes the Hey-ok is awesome. Works great and solved my issues.
10-05-2014, 08:54 PM | #15 |
Cool thanks bud. Can you tell me which controller you got. I was looking on rpp hobbies and there are different ones. Still kinda new at all the electronics stuff.
10-05-2014, 08:59 PM | #16 |
Two KMS winches and two HeyOk 4 amp relay controllers. Works killer Last edited by Norton; 10-05-2014 at 09:04 PM. |
10-05-2014, 09:23 PM | #17 |
Would like to have those servo winches. But that's not in my budget. I have the warn wireless winch and it does what I need it to. I have the same rear bumper as you is why I want to do the duel warn winches. Just not sure what heyok controller to get for them.
10-05-2014, 09:26 PM | #18 |
Got my new controller. So I was wanting to do two wired winches and seen people where still having problems with rc4wd wired controllers.
10-07-2014, 09:12 PM | #19 |
Heyok can make a custom one with a toggle and 2 feeders so you only need 1 channel.
10-17-2014, 10:46 PM | #20 |
My controller has two 3 position switchs on it. Just don't know winch one of the hey ok controllers will work.
RC4wd new Warn winch problems - Similar Threads | ||||
RC4WD 1/10 Warn 9.5cti Winch | Rckcrwlr | General Scale Talk | 86 | 06-06-2016 01:33 AM |
rc4wd warn wireless winch | diffman33 | Newbie General | 21 | 05-20-2016 04:59 PM |
