04-09-2014, 02:31 PM | #1 |
Newbie Join Date: Nov 2013 Location: canada
| positive negative hook up on moter
So i mounted my motor and the rsc (holmes hobby) and i realized that i have them backwards and i already cut the wires to size on the rsc i thought white was negative and black was positive for some stupid reason so my question is what happens if i hook up the motor backwards from the rsc ? is there a way i can change it on the controller like reverse it ? cause my understanding is if its wired backwards then forward would be reverse and reverse would be forward correct me if im wrong
04-09-2014, 03:03 PM | #2 | |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: positive negative hook up on moter Quote:
04-09-2014, 03:05 PM | #3 |
Moderator Join Date: Jan 2004 Location: chicago
| Re: positive negative hook up on moter |
04-09-2014, 03:15 PM | #4 |
04-09-2014, 03:53 PM | #5 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Also----Make sure the lights on the esc are ramping up the proper direction also. Meaning when you pull forward throttle you should see a green light...reverse, you should see a red light.
04-09-2014, 04:01 PM | #6 |
so is it okay to wire backwardsor should i remount my moter a wire it up right i have a dx 3e tx so would i just be able to reverse it on there?
04-09-2014, 04:17 PM | #7 |
| Re: positive negative hook up on moter Reversing the radio will make the ESC run reverse, which you don't want to do. You want FWD on the radio to be FWD on the ESC, always.
04-09-2014, 04:18 PM | #8 |
What speed control are you using?
04-09-2014, 06:14 PM | #9 |
so remount the engine is the only way to fix this i take it ?
positive negative hook up on moter - Similar Threads | ||||
Rear Steering - Use Positive or Negative Caster? | NitroStar | Axial SCX-10 | 2 | 02-19-2014 12:39 PM |
just installed moter | insutama | Axial SCX-10 | 8 | 01-13-2014 04:33 AM |
negative and positive wiring? | Coffinspire15 | Newbie General | 7 | 06-11-2011 07:29 AM |
moter | jwessel | Newbie General | 3 | 10-24-2010 06:22 PM |
