04-10-2014, 04:17 AM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: Central PA
| Is it bad to stuff all your electronics into one box?
I was just curious because the way I want to set my scx10 up, I would have batteries on the slider bars and a box up front which I can fit my Rx, esc, bec, and winch controller all inside of. It's a tight fit but would keep most water out under normal situations. I was just wondering if it may have adverse affects or would it be fine to do it like that?
04-10-2014, 06:20 AM | #2 |
Rock Stacker Join Date: Dec 2013 Location: The Woods
| Re: Is it bad to stuff all your electronics into one box?
The main thing to be aware of is the ESC, if you are not running a high powered (i.e. high heat) configuration you should be ok IMHO.
04-10-2014, 07:34 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Like mentioned, heat could be somewhat of an issue, depends on what your running for power, and the only other possible issue would be radio interference. Sometimes receiver antennas don't like to be around servo wires, or sensored brushless cables. Since your going waterproof the brushless isn't probably a big deal, but I would say if you jam it all in there, just give it a trial run quick around your yard or something before you seal it all up, just to be sure you don't have any interference or glitching issues. |
04-10-2014, 07:38 AM | #4 |
I'd say EMC (electromagnetic coupling) can be another issue besides heat. At least BEC and ESC use components that operate at radio frequencies, and this might cause problems with the Rx. One solution is to wrap BEC and Rx in tin foil and try to keep the wires separated. |
04-10-2014, 08:21 AM | #5 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
Heat... I stuffed an fxr, bec & rx in a radio shack box (tight fitting jeans forsure) on 3s. Running the lid on during cool weather works good unless your getting it for long periods of time. Summer time....forget about it, would thermal quick like. I don't bother to the run the lid on it anymore and it works just fine (just not as WP as I had intended) |
04-10-2014, 01:07 PM | #6 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Is it bad to stuff all your electronics into one box? Quote:
All this makes me think of is Ron Howard in a tin foil hat! Lmao I've never had emc issues except once when stacking a savox servo on top of a 400 can open end puller motor. The rest being circuits have had zero emc issues. I've seen many smashes stacked up with good results Only issues I've seen or had is heat depending on run time and gearing. I would run for 15 hard and check temp and repeat every 15 and go off of that. Should give ya a good clue on your set up | |
04-10-2014, 01:28 PM | #7 |
Thanks for the tips. I ran my fxr with 35t motor on 3s last summer and never had any heat issues, but I have more than one top so I can drill one to vent it for warmer days I guess. Heck I have an extra fan or two from crap escs I could probably put one on top.
04-10-2014, 04:55 PM | #8 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
I have my ESC and RX in the same box on my SCX10's without issues.
04-10-2014, 05:01 PM | #9 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
It shouldn't cause a problem. My decased FXR, receiver and BEC are all tightly packed into a space smaller than the Axial radio box. There are zero issues with interference or heat. My next build will have all of the electronics in a smaller package; everything will be basically smashed together. |
04-11-2014, 08:00 PM | #10 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
I have a RX8, RX and BEC in one box. It does fine with the 4300 Pro4 on 3s. the box does get hot but doesn't thermal. The MMP I had before would thermal with the same set-up.
04-11-2014, 09:47 PM | #11 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
All depends on the heat ... which can depend on your motor & gearing, etc.
04-11-2014, 11:24 PM | #12 |
Ach! Damn the nay-sayers, and give 'er a go! (shrug) Maybe it works, who's to say? Not sure how bad of an idea it is, only had JUNKFOOT! out on one trail ride. And that was a crisp, fall day. Don't know how it'll do in the heat of summer. |
04-12-2014, 02:17 AM | #13 |
Pebble Pounder Join Date: Jun 2008 Location: Carmichael
Check out this build by Mike Pham. Incredible build and he puts all his electronic items in traxxas waterproof boxes. Pham's - nissan_driver24 - Axial SCX-10 JEEP WRANGLER G6 Kit Build |
04-23-2014, 10:11 PM | #14 |
Rock Crawler Join Date: May 2011 Location: at your moms
I do it routinely when building rigs, a fxr, receiver. bec and used to be winch controller in the same radio shack box, been doing it for years without issues so far, I would watch your gearing ect to keep it from overheating
04-24-2014, 06:25 AM | #15 |
Old setup.. Fxr deceased w/4s cap, Rx decased, and Rx decased.. Running 4s an a 16t crawlmaster pro.. New setup.. Tekin RS w/4s cap an Rx decased.. Running 4s.. Just haven't figured out how to get the bec in there.. Yet.. Never a issue.. Run it! |
Is it bad to stuff all your electronics into one box? - Similar Threads | ||||
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
Electronics box | SC Convert | Axial Wraith | 20 | 06-18-2011 03:16 PM |
how bad are the electronics really? | noremacyug | Axial SCX-10 | 16 | 04-10-2011 01:14 PM |
sealed electronics box? | RTVIC | Redcat Crawlers | 10 | 09-11-2010 03:44 PM |
box for electronics | silverbullet | Electronics | 5 | 04-05-2006 06:52 AM |
