04-10-2014, 04:20 PM | #1 |
Newbie Join Date: Mar 2014 Location: medford
| misfire help
My ESC motor misfire what does that mean and what would cause it
04-10-2014, 05:03 PM | #2 |
| Re: misfire help
This is new... What EXACTLY do you mean by 'misfire'? What electronics are you running, under what conditions are you running, and what exactly is the problem? |
04-10-2014, 05:44 PM | #3 |
| Re: misfire help
Running Holmes hobby trailmaster 3100 and Novak crusher ESC. ESC will read misfire detectectuon. When it first starts the truck won't move unless I give it a push. Then it'll go for about 20 sec then goes to misfire
04-10-2014, 05:52 PM | #4 |
| Re: misfire help
Could it be the motor is bad this is the second esc and only ran about 10 or 15 full batteries all yigather
04-11-2014, 11:28 AM | #5 |
| Re: misfire help
Ran this morning b4 work for a cple minutes and worked fine. I have 18t and 87t pinion and spur gears could that cause a problem
misfire help - Similar Threads | ||||
Cylinder 3 misfire | Duuuuuuuude | Chit Chat | 33 | 02-27-2012 03:31 PM |
Ax10 starting to misfire | Kanine38 | Newbie General | 12 | 02-25-2010 06:25 PM |
