04-12-2014, 01:02 PM | #1 |
Newbie Join Date: Mar 2014 Location: United Kigdom
| BEC query
Hi all. If you have a Bec that say has an output of 6.0v the max for your servos If this bec is the supply to your esc your motors are 7.2v are they only going to receive 6.0v and be under powered? |
04-12-2014, 01:08 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: BEC query
If it is hooked up correctly, your BEC should handle only the accessories, servo and provide power to the RX. The ESC has a separate system on the mother board for the motor. If you plug in a 3S Lipo (11.1v), 11.1v will go to the motor and then the BEC will cut down that power and distribute it to a servo or lights that you have set your voltage value to. It's other name is a switch regulator and, in a way, can be related to a transformer. Last edited by Lentsnh2012; 04-12-2014 at 01:11 PM. |
04-12-2014, 02:39 PM | #3 |
| Re: BEC query
Thx for the prompt reply, totally understand now.
BEC query - Similar Threads | ||||
Diff Locker Query | thzero | Axial AX-10 Scorpion | 5 | 02-19-2011 11:00 AM |
SCX10 Kit - Steering Query | stewbaru | Axial SCX-10 | 8 | 02-01-2011 09:09 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
