Problem with hh 13.5 i bought a 13.5 trail master in February. Put it in my wife's wraith that way in a little over 7 pounds gear mesh was set properly. Took it out yesterday and it just stop running it only runs on 2s and was not hot . Got it home pulled motor and put it on the esc in my honcho and it ran real slow and stutters. After running it at about 1/4 throttle for less then a minute it it started to get hot. Any thoughts on what happened to it. Thank you for you're help in advance |
Re: Problem with hh 13.5 Or how to warranty it. |
Re: Problem with hh 13.5 Just give them a call and im sure they will help you resolve the problem..more than likely they would want you to send it in and they will repair if its under warranty and send it back to you or it may be something simple they can talk you through over the phone...I don't know..I would call though. |
Re: Problem with hh 13.5 Sounds like you may have cooked a winding. What were you doing when it started acting up? |
