04-14-2014, 10:22 AM | #1 |
| Direct Servo/BEC wiring diagram help: Does signal wire require ground?
ok. on my scale trucks. i have steering servo (HV), and a winch servo (heyok controller strictly limited to 6v old version) so i want to directly wire my steering servo to a external BEC(HV), and let the ESC BEC power the Rx and winch servo(6V). is this possible? so i want to make one of these so i dont have to cut the servo or BEC leads. Here is the diagram i came up with. *is this correct? *does the signal wire require the ground that goes from the "G" to the RX? or does it only need to go from the BEC to the Servo? the adapter above goes to all 3 it appears. * on the adapter above the signal appears to come from one of the plugs that are glued together but the ground comes from the other plug. but theres a jumper between the two. so does the origon of the ground from either glued end not matter? because of the jumper? *since i will have "two" becs running, is there any chance of any kind of back power feed threw the signal wire/ground back to the rx threw the adapter/diagram above? does having the ground wire from the "G" to the RX affect this answer? thanks! -Cory |
04-14-2014, 10:36 AM | #2 |
| Re: Direct Servo/BEC wiring diagram help: Does signal wire require ground?
Search newb! Futaba shouldn't have an issue without the ground but spektrum freaks out some times without it.
04-14-2014, 10:37 AM | #3 |
never would have thought that would matter. i am on Futaba.
04-14-2014, 05:32 PM | #4 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
You're exactly right to think of it as another BEC because thats what it is. If you're only running six volts you could just run it through the reciever and be fine (if the power wire from your esc is disconnected). Otherwise your diagram from the servo side looks great (I used to run that exact setup). I always prefer to run a ground to the receiever. Also: Quote:
04-14-2014, 05:46 PM | #5 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
| Re: Direct Servo/BEC wiring diagram help: Does signal wire require ground? |
04-14-2014, 08:50 PM | #6 |
Quarry Creeper Join Date: Nov 2013 Location: lethbridge,alberta, its mighty windy here!!
its always a good idea to keep the ground connection along with the signal. in circuits that are interconnected the gnd connection between each individual circuit helps to act as a voltage reference point between them whether they are individually running seperate power or shared power. in one of my circuits i make the microchip side runs one voltage and the other half runs at 3s voltage, the gnd connection between them is the reference point that allows trouble free operation between the two. most bec circuits that people will run in their rigs will be run from the same power source so you can avoid that gnd connection with the signal wire but ideally it should be included as it makes it one less culprit when somethings not working right and its time to troubleshoot tony |
04-15-2014, 02:20 AM | #7 | |
| Re: Direct Servo/BEC wiring diagram help: Does signal wire require ground? Quote:
IMO, the OP's diagram is spot-on, just needs to make it happen. Check all connections before powering up, make sure there's no red connection at the receiver, and you should be set. Report back and let us know how ya make out. | |
04-15-2014, 10:08 AM | #8 |
Pebble Pounder Join Date: Mar 2009 Location: buford
I use these cut off the prong for the red going to the rx and make a pig tale for the signal and ground to the rx. This set up seem a little smaller to me.
04-16-2014, 12:47 PM | #9 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Direct Servo/BEC wiring diagram help: Does signal wire require ground? - Similar Threads | ||||
CC BEC Signal Wire | jaloos | Electronics | 6 | 10-08-2013 07:40 PM |
BEC and other wiring (see diagram) | pritch | Electronics | 4 | 09-11-2011 05:20 PM |
BEC Wiring Diagram... | justinart24 | Electronics | 0 | 12-15-2010 11:16 PM |
castle bec? what does the signal wire do? | driftin90 | Electronics | 2 | 07-19-2009 05:16 PM |
Signal wire from the CC BEC do anything? | swell searcher | Electronics | 2 | 07-16-2008 04:29 PM |
