View Poll Results: Which one is better? Corrosion XHD VS Plastic Dip | |||
Corrosion XHD | 12 | 66.67% | |
Plastic Dip | 6 | 33.33% | |
Voters: 18. You may not vote on this poll |
04-14-2014, 10:36 AM | #1 |
Pebble Pounder Join Date: May 2010 Location: sac
| Corrosion X(HD) vs Plastic Dip
Thinking to try Corrosion X-HD..Not sure yet. What do you think?
04-14-2014, 10:39 AM | #2 |
| Re: Corrosion X(HD) vs Plastic Dip
Neither. Do it right with conformal coating. Its made for waterproofing electronics.
04-14-2014, 10:50 AM | #3 |
| Re: Corrosion X(HD) vs Plastic Dip |
04-14-2014, 10:54 AM | #4 |
| Re: Corrosion X(HD) vs Plastic Dip Conformal coating is what the OEM uses to waterproof electronics. I use MG Chemicals 419b. Its about $10 from amazon or eBay and is enough to waterproof everything you own. I regularly completely submerge my junk and have 100% success.
04-14-2014, 11:24 AM | #5 |
Thanks ..do you know what spektrum company use to waterproof their rx?
04-14-2014, 11:58 AM | #6 |
| Re: Corrosion X(HD) vs Plastic Dip This is good stuff and waht I use besides boxing up electronics. |
04-14-2014, 12:12 PM | #7 |
04-14-2014, 12:15 PM | #8 |
| Re: Corrosion X(HD) vs Plastic Dip Take the case off the ESC and brush it on the board working it in everywhere. I let it tack up and apply another coat. Let it dry and put it back in the case. Obviously use dielectric grease on buttons and Rx plugs like you would with any waterproofing method.
04-14-2014, 12:18 PM | #9 |
| Re: Corrosion X(HD) vs Plastic Dip Nice...thanks a bunch..how to protect the servo by using MG419b, please? thx
04-14-2014, 12:21 PM | #10 |
04-14-2014, 12:31 PM | #11 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: Corrosion X(HD) vs Plastic Dip Quote:
I do use corrosion X and silcone on my Pro4's just to keep junk out of them, but even then I've been using conformal on the boards themselves. | |
04-16-2014, 06:12 AM | #12 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
Great info fellas.
06-21-2014, 01:35 AM | #13 |
Quarry Creeper Join Date: Dec 2007 Location: Central Florida
So is ok to dip the ESC in conformal coating but not the motor / bearing? If it rotates use corrosion x or dielectric grease and not conformal coating? Asking before I do it Thanks! |
06-21-2014, 10:52 AM | #14 |
Apply the conformal coating as the instructions suggest - the stuff I have is aerosal, so I spray a few coats on to get the proper coverage, but some types of conformal coating are brushed on. I would think that dipping it might result in too thick of a coat to cure properly (think of it like paint). On the last Pro4 I did, I just dipped the sensor board in Corrosion X, then siliconed the crap out of the can everywhere there was a gap with blue electronics safe gasket making silcone. My theory is that if any water finds its way in, the only part of the motor that is really succiptible is the sensorboard. I think I perfer this method because it makes sure your sensor isn't gumped up with conformal coating. I only use dialectric grease on plugs (like the sensor plug) and servo plugs. Hope that helps. Last edited by Highmark; 06-21-2014 at 10:57 AM. |
06-21-2014, 12:11 PM | #15 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Corrosion X is more like an industrial wd40. It displaces water. I believe the conformal coating actually encapsulates the part to keep the water away. Corrosion X works great, but it is more of an ongoing treatment vs the Conformal that I believe would be a single time and you should be good.
06-21-2014, 05:20 PM | #16 |
Which model number of conformal coating are y'all using?
06-21-2014, 05:29 PM | #17 |
06-21-2014, 05:44 PM | #18 |
Thanks bud. I was about to buy the 4226
06-22-2014, 02:04 AM | #19 |
Instruction are kind of vague, but it does mention you could dip the part. I have the brush on. So I assume that conformal coating the whole motor is a big no due to the bearings, no one have feedback on that. It seem that conformal the board, grease the plug and a few drop of corrosion x at the front bearing is the way to go then? |
06-22-2014, 12:46 PM | #20 |
The conformal coating is for the electronics. I use silicone and marine grease for mechanical parts.
Corrosion X(HD) vs Plastic Dip - Similar Threads | ||||
plastic dip hard spot | Ohioskills | Electronics | 0 | 03-08-2014 05:34 PM |
Plastic dip | kalifkid | Chit Chat | 26 | 12-05-2013 11:48 AM |
plastic dip battery | rider12693 | Electronics | 2 | 09-29-2008 07:25 PM |
re-oiling motor and plastic dip | muddeprived | Electronics | 5 | 04-13-2007 11:54 AM |
