04-14-2014, 06:01 PM | #1 |
Newbie Join Date: Sep 2012 Location: Brooklyn
| Axial receiver/transmitter problems. Please help
Wraith runs in reverse when I turn off the transmitter. Also if I run it too Farr away it loses reception. If both receiver / transmitter are off and I turn on receiver only there's no problem. It's only after both are on and transmitter is turned off. Bought net receiver, worked well after awhile but now same problems. Please help. Searched the forum too but can't find a thread on this problem. Thanks
04-14-2014, 06:22 PM | #2 |
| Re: Axial receiver/transmitter problems. Please help You should always turn off the receiver before turning off the transmitter. When you go out of range or turn the transmitter off first, the receiver goes into fail safe mode. The behavior of the fail safe mode can be changed so that your rig will stop. The steps for programing the fail safe mode is on the lower left hand side of the AX-3 instructions. http://docs.axialracing.com/instruct...structions.pdf Last edited by k7zpj; 04-14-2014 at 06:26 PM. |
04-14-2014, 06:51 PM | #3 |
Ok thanks I'll try changing it.
04-15-2014, 02:46 PM | #4 |
It worked!! Thanks!! I'm an idiot lol
Axial receiver/transmitter problems. Please help - Similar Threads | ||||
any have problems with transmitter/receiver | gofaster427 | Axial Wraith | 4 | 03-03-2012 09:50 AM |
