Thread: to bec or extra battery
Old 04-15-2014, 08:57 PM   #1
Default to bec or extra battery
wondering what would be the better route im running 2 d772 servos off my reciever and there not getting enough power it seems and i also have a winch on the rig wondering is i should just run them to a seperate battery or run the servos off a bec or or can i just run there power directly off the battery? and elimanate a bec ether way
im running a venom 2s 5000 mah 20c battery right now i get about hr and a half run time crawling/ messin around
ben h is offline   Reply With Quote
Old 04-15-2014, 09:37 PM   #2
Default Re: to bec or extra battery
If all your electronics will survive 8.4 volts ( fully charged 2s lipo) then hardwire them to the main battery. Most servos will not survive extended use at such high voltages.
The Violator is offline   Reply With Quote
Old 04-15-2014, 09:47 PM   #3
now that u put it that way it makes sense i will get a bec then
Old 04-15-2014, 09:52 PM   #4
Its more efficient to run a bec. No pack worth using will be as small.
Meatwad is offline   Reply With Quote
Old 04-15-2014, 10:00 PM   #5
ok is there a certain amp i should get? ( amp rating on bec) the servo it self doesnt have a amp rating listed
Old 04-15-2014, 10:53 PM   #6
The castle bec is 10amps and works well for others as well as myself. Lights, winch and steering servo all at once... No issues for me.
Old 04-16-2014, 07:06 AM   #7
If you want to power 2 servos AND a winch I would look at castles BEC pro. I ran one on my super running 3 servos without issue.
I would plan on 4-6 amps per item you want to run. Castle BEC pro is 20 amps. If packaging it all in a confined space is an issue 2 standard castle BEC'S will also work but would require some additional separation of the wiring.
BEC pro for the win!
Old 04-16-2014, 09:00 AM   #8
well i will probly just run the winch right from the battery since the winch can handle the voltage but i am also building a 6x6 that i plan on doing 6ws so ill get the castle pro for that one and just use the regular one for this truck how easy are they to program? i wish the heyok on was higher amp rating its just a screw on the side
Old 04-16-2014, 09:16 AM   #9
If you have a castle link and the software already set up from castle esc programming, the bec takes literally 30seconds to setup. If you don't, buy it from your lhs with the stipulation that you need it programmed for you.
Old 04-16-2014, 09:27 AM   #10
that would be a good idea lol but the closest hobby store is hr and a half away but ill get the software to do it i guess
Old 04-16-2014, 07:50 PM   #11
Location: Turn the mayflower around.. it will never work
Software is free..... Download from cc website. Castle link is what you will need to buy, even tho they used to be free with esc purchace long ago. But is great investment to be able to use on cc escs and the like along with bec programing.
JokersWild is offline   Reply With Quote
Old 04-16-2014, 08:53 PM   #12
Or post a few more times and get one in classifieds. Most people will program them for you
Also if it was me I would split the BEC feed and feed the servos directly with the power. Then run the signals to the receiver. I would let the receiver be powered from the esc and just power the winch from there. If you have the room with the winch controller for the voltage then it could be hard wired as well.
Good luck
tgh117 is offline   Reply With Quote
to bec or extra battery - Similar Threads
BEC or separate battery ed701 Newbie General 16 03-24-2013 06:13 PM
Extra Battery Jimbeaux General Crawlers 7 01-03-2006 12:42 PM
