04-16-2014, 06:28 PM | #1 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
| brxl cuts out
So I just installed a new brxl in my wife's rig and now I'm having an issue, if I'm giving it anything more then enough throttle to barely make the rig move and steer it cuts off the throttle and it won't give me throttle back until I let off the throttle then I'm good to go as long as I leave the steering where it's at if I turn the other way or even let the servo center and it cuts out again. Setup is Brxl bec set at 6.0v 7.4v 5300mah 70c battery Brood 2011 limited edition 35t scaler motor Savox 0231 wp servo Heyok winch controller Spektrum dx4s and sr4100 |
04-16-2014, 06:39 PM | #2 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| Re: brxl cuts out
Use an external BEC, your Savox is causing a brown out.
04-16-2014, 07:43 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: brxl cuts out
X2..... More likely needs bec. Always run one. Second may want to look at swapping out that servo also to a better unit. |
04-16-2014, 09:07 PM | #4 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
| brxl cuts out
Yep I agree as well. Needs a BEC or at least one of those spectrum capacitors they had back in the day. You could verify it by unplugging the steering servo and testing once more, but it seems that abec will take care of you |
04-16-2014, 10:13 PM | #5 |
| Re: brxl cuts out
That's what I thought just wanted to check before I pay to have it done, thanks guys.
04-17-2014, 12:32 AM | #6 |
| Re: brxl cuts out Back in the day? Like yesterday? They are glitch busters and they still have em at most tracks, novak, racers edge hell even venum sells one . Last edited by JokersWild; 04-17-2014 at 12:35 AM. |
04-17-2014, 09:31 AM | #7 |
I had no clue they were still around. I have one sitting on my bench from the first day I put 4ws on the ax-10 when it was released. Everyone is on the BEC bandwagon anymore, which is good for most cases, but that buster works in a pinch.
04-17-2014, 05:54 PM | #8 |
| Re: brxl cuts out Yea the cap/ buster works in a pinch. But ya already know it fixes same types of issues but really different beasts. Bec you can up your voltage....... Buster is just a capacitor that stores an amount of power mainly on a track rig from glitching out during hard main starts and rocketing out of tight corners but only for a few seconds. All my track rigs have always been set up like my crawlers to be adjustable and ran directly to servo to get down under .05 speed wise by raising voltage above recommended #s and changing the deadband.... I also fo the same on my 3d planes. Way faster reaction!...... Snap rolls like now. |
04-18-2014, 06:54 AM | #9 |
Rock Stacker Join Date: Aug 2011 Location: NE Calgary, Alberta, Canada
| Re: brxl cuts out |
brxl cuts out - Similar Threads | ||||
Ae-2 Cuts Out | MattyO | Electronics | 11 | 10-01-2013 05:02 AM |
Steering cuts in and out | Big Sarge | Vaterra Twin Hammers | 2 | 08-13-2013 07:32 PM |
BRXL Giveaway & The Next Team Driver Contest - 1 RCC User will win a BRXL this week!! | Locked Up | General Crawlers | 205 | 10-22-2012 10:49 AM |
cuts out | macs406 | Electronics | 3 | 01-19-2010 06:07 AM |
