04-19-2014, 06:57 PM | #1 |
Rock Crawler Join Date: Mar 2014 Location: Yorkville
| Tekin rs gen 2
so i have a tekin rs gen2 and i wired up my brushless motor and for some reason its running in reverse and its sensored the phases are hooked up correctly and the sensor wire is brand new, any idea whats going on? if i try to reverse my throttle trigger it just sends the car zipping off in reverse still.
04-19-2014, 07:08 PM | #2 |
Moderator Join Date: Jan 2004 Location: chicago
youll need to reverse the motor rotation via tekin hotwire.
04-19-2014, 07:17 PM | #3 |
| Re: Tekin rs gen 2 |
04-19-2014, 08:51 PM | #4 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
You could have also swapped you reverse on your throttle Chanel, you would have just needed to re calibrate the esc after.
04-19-2014, 10:22 PM | #5 |
04-21-2014, 04:06 PM | #6 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Tekin rs gen 2
What motor are you using? Reversing the throttle channel isn't the best way to do it, the ESC will be running in reverse. |
Tekin rs gen 2 - Similar Threads | ||||
Tekin RX8 Gen 2 | cmnyj28 | Axial Wraith | 3 | 10-07-2013 06:35 PM |
Tekin RS Gen 2 | cherokee pat | Electronics | 5 | 08-26-2013 11:01 AM |
