04-22-2014, 11:33 AM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
| I need to get the CC BEC install Clear in my head
I have the CC BEC and MMP with a Futaba 2030GF receiver. Do I have this correct in thinking 1. The MMP has a yellow, red, and brown colored wires from the ESC. I remove the RED wire from the ESC connector and install into #2 of the rx. 2. With the CC BEC being powered from the battery, plug this into the BATTERY port of the rx. 3. Hitec servo then plugs into #2 of the rx. What I am not sure of is: On the 2030GF rx, what is signal, + and - ? I'm afraid of plugging the CC BEC in backwards and Browning out the MMP. |
04-22-2014, 12:09 PM | #2 | |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: I need to get the CC BEC install Clear in my head Quote:
The red wire is in the middle. So if you plug anything in backwards you will only mix ground and signal. By pulling the red wire from the esc you are just eliminating a second power source. Adding a BEC is a simple thing, just make sure to pull the red wire from the esc to the RX and you really should not be able to damage anything if you make a mistake. | |
04-22-2014, 12:45 PM | #3 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
On the receiver a good rule of thumb is "1 to turn, 2 to burn" slot 1 = steering slot 2 = throttle Last edited by el_Fernando; 04-22-2014 at 02:42 PM. Reason: I' am dyslexic |
04-22-2014, 01:00 PM | #4 |
Thanks - I did somehow think I fried my SCT3 trying to hook the BEC up a while ago. So I'm gun shy but I think I have it now. I used a an extension on the MMP wire that had the middle wire cut. Which SHOULD have done the same thing as removing the red from the MMP. Not sure what went wrong. |
04-22-2014, 01:42 PM | #5 |
Do I need to cut any of the 3 wires coming from the CC BEC in the ESC? Sent from my SCH-I545 using Tapatalk |
04-22-2014, 01:54 PM | #6 |
Here's how I'll set it up..look good? Isn't it 1 to TURN 2 to BURN? |
04-22-2014, 02:11 PM | #7 |
Pebble Pounder Join Date: Feb 2013 Location: Fresno
It's always been 1 to turn and 2 to burn. Channel 1 is steering Channel 2 Esc |
04-22-2014, 02:42 PM | #8 |
That's what I thought. El Fernando wrote it backwards Sent from my SCH-I545 using Tapatalk |
04-22-2014, 02:47 PM | #9 |
The easy way for me to remember is counting down, the steering is physically higher than the trigger. So 1 for steering, 2 for throttle. Left to right, top to bottom like reading. Usually on the rx, ground will be facing out. |
04-22-2014, 03:00 PM | #10 |
I think I'm solid on knowing what to do n how. Only down side is I can't program my cc bec to 6v for the 7955 because I don't have the cord Sent from my SCH-I545 using Tapatalk |
04-22-2014, 03:58 PM | #11 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Dont cut anything! slide the red wire out of the plug for the ESC into the receiver....you do not need this power source. You are going to power the Receiver (and subsequently the servo) using the BEC plugged into the Battery port on the receiver. You do not want to have 2 or more power sources going into the receiver - the red wire on the ESC harness is a power source that comes from the ESC to the receiver to power all the items plugged into the receiver. - if you take that wire out, you have to replace it with something....in this case, you're using the BEC to provide power to the receiver. Tape the red wire that you took out of the harness with electrical tape to keep it from grounding on anything....its still a source of voltage. You will need all 3 wires on the BEC for programming. If you cut the orange wire, you will not be able to program the BEC. leave it as is and be happy Why a BEC, because it is built to provide up to 10 amps for accessories on your rig...servo included. the stock ESC "internal BEC" is only 3-5 amps depending on the manufacturer and they are not programmable....typically set at 5v. So, you're bypassing the weak "Internal BEC" and using an "External BEC" which is more stable, stronger and versatile! Last edited by redsawacs; 04-22-2014 at 04:03 PM. |
04-22-2014, 07:17 PM | #12 |
| Re: I need to get the CC BEC install Clear in my head |
04-22-2014, 07:30 PM | #13 |
Got it all hooked and rockin. Definitely quicker steering than before. Be nice to get it bumped to 6v though. Sent from my SCH-I545 using Tapatalk |
04-23-2014, 06:57 AM | #14 |
I did not cut anything. I uses am extension from the ESC to the rx and removed the center wire from it. It all works good now! Thanks everyone. It really was easy |
I need to get the CC BEC install Clear in my head - Similar Threads | ||||
Bec install! | Reaxion911 | Micro Scale Rigs | 11 | 04-13-2014 11:52 AM |
Could use some help with CC BEC install | Markeje | Electronics | 8 | 03-21-2014 08:33 AM |
BEC Install | markmc90 | Axial Wraith | 3 | 03-31-2013 03:08 AM |
Bec Install | lurchy | Electronics | 8 | 01-02-2013 04:48 AM |
Gear Head Trail Torch LED Lightbar install ? | mrmagoo | Axial Wraith | 3 | 02-05-2012 05:02 PM |
