04-27-2014, 01:47 AM | #1 |
Rock Stacker Join Date: Jan 2009 Location: Winnipeg, Mb
| Lipo batt overheating from my SV3
I am currently building a TF2 & the electronics I'm using are a cc SV3, integy 35t brushed motor, cc BEC set @ 7.4v & a savox digital high torque servo. Anyways I hooked everything up plugged in a 3s 1300 lipo pack & the truck starts moving forward I unplugged the battery & plugged it back in & doesn't want to arm the lights are flashing red so & I have no throttle response. So I solved the issue by setting the end points in my radio to neutral now the truck is working properly but reverse doesn't seem to be working smoothly it would jerk back constantly when you reverse the trigger then all of a sudden my lipo would start smoking & overheating! I unplugged the battery & let it cool down then I would try it again but it does the same thing has anybody had this same issue happen where the battery would all of a sudden smoke & get hot when you pull the trigger? Is there something wrong with my setup? I wanna get your feedback thanks!
04-27-2014, 02:27 AM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Lipo batt overheating from my SV3
Sounds like you could have a few issues. Did you calibrate the ESC to the Tx as per the manual? Secondly, what C rating is the LiPo you're using? Thirdly, closely check all your connections including the ones you soldered.
04-27-2014, 07:36 AM | #3 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
Do you have another motor you can try? This happened to me once. Had a castle brushless motor short/ground out and it did basically the same thing. Got so hot it melted the the deans/ solder connection off my thunder power 70c battery
04-27-2014, 11:58 AM | #4 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Sounds like a dead short. If the battery got hot enough to smoke, get rid of it.
04-27-2014, 01:48 PM | #5 |
Hmmmm, ok so I used different lipo batts that I have & they did the same thing by starting to overheat so I disconnected everything & pulled the esc outta the truck. I hooked it into my computer via cc link same with the BEC & everything is still working fine so when I plug in one of my lipo batteries to the sv3 with nothing hooked up all the lights would flash & start beeping I would hold the wires from the battery & within seconds it would rapidly get hot then I have to switch the esc off! I would try the same battery on my other crawlers that also use sidewinders & they would work fine it's only when I would plug it back into the sv3 then it would start to overheat the battery. Do you think that this is an issue with the sv3? I just recently purchased this thing & this is the first time I've used it & it's giving me these issues do you think I should send it in to castle for warranty? |
04-27-2014, 02:28 PM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Canada
absolutely an issue with the SV3 if you've tried multiple batteries. Give castle a call, they will back up their product, always do.
Lipo batt overheating from my SV3 - Similar Threads | ||||
Lipo batt expanded!!! | coldcrawlr | Electronics | 6 | 03-10-2011 02:12 PM |
What lipo batt for AX10 | rcdth | Newbie General | 1 | 10-24-2008 02:20 PM |
Is My LiPo Batt Gone?? | Robb | Electronics | 31 | 04-29-2008 10:54 PM |
