About the Axial Ae-2 Lipo Cutoff settings. My neighbor has a wraith with the stock electronics in it, other than a 55turn motor. He had horrible run times on a 2s battery, so I hooked it up to the castle link to fiddle around and when I try to set the lipo cutoff to something like 3.4 or 3.5, like I have set on my fxr which is even a bit safer than absolutely necessary. But when I try to set the AE-2 below 4.0, it does not save it. After I update it and disconnect the esc, I open it in castle link again and it reverts to 4.0 volts for the lipo cutoff. Is this how the AE-2 works, or does he maybe need a firmware update? |
Re: About the Axial Ae-2 Lipo Cutoff settings. Update the firmware and set it at a reasonable level. I set all mine to 3.1 volts for longer run times. |
Re: About the Axial Ae-2 Lipo Cutoff settings. Thanks. I will see if a firmware update will help. Because he was getting like 20mins or so off a 4000mah battery pack with a 55turn motor in it. I still keep telling him he needs an external bec, though. Lol. |
Re: About the Axial Ae-2 Lipo Cutoff settings. If he's going to stay 2s I'd just wire the servo directly to the battery. If he may upgrade to 3s later may as well get a CC bec now and be done with it. My AE2 hasn't seen 2s in the 2 years I've had it, 3s only. It's a solid esc. :D |
Re: About the Axial Ae-2 Lipo Cutoff settings. After I got into flying 3d foamies that voltage sag the little packs pretty bad I started running a 3.0v cutoff on all my junk. I have some packs that are 5+ years old that still work fine. Imo you guys that run really conservative cutoffs are just wasting run time. |
