07-21-2014, 09:22 PM | #1 |
Rock Stacker Join Date: Jun 2012 Location: Santa Monica/Venice
| New to lipo, need help!!
Ok, just got a new lipo charger for my new Zagi-33's 3S 2100mah batt. The batt tells me I can charge this at 10.5a (5C) is that safe?! What should I be charging this at? |
07-21-2014, 09:27 PM | #2 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: New to lipo, need help!!
5C is a common charge rate MAX. I only charge and 3C max, just a personal preference. 2.2amps is 1C 4.4=2c 6.6=3c you get the idea... |
07-21-2014, 09:33 PM | #3 |
I'm using a Team Tenergy charger. I'll charge it at 3c
07-22-2014, 06:39 AM | #4 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
I prefer to charge at 1c, but I am never in a hurry.
07-22-2014, 07:59 AM | #5 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: New to lipo, need help!! |
07-22-2014, 09:39 AM | #6 |
I charged once at 5.0A using a 3s 2200mah/30C After the charge had completed... a coupla' minutes went by... then all of a sudden the pak began to swell. when I realized what was occurring... I ran outside with the LiPo and placed it on the cement patio. In another 30 seconds it burst... then caught fire ! I use a Hobby People TAZR auto detect LiPo charger that allows the amps to be adjusted. but I now charge mine at 2.1A (1c) as I didn't like the outcome of that LiPo burst. I have not had that re-occur since... and I have more then a few of this particular 3s LiPo. I don't mind the wait... as I usually charge up my all of my LiPo's the evening prior to the day's use. But then... it was pointed out to me that I have cheap batteries and that was to blame. Most mfgr's/distributor's will not warranty a LiPo that has burst and burned to ash. Justifiably, because there is no evidence remaining, after it bursts and burns, to verify whom was the mfg'r/dist. Fast, high amp charges will also reduce the life cycles of the LiPo. So a slower charge at lower amps is less stressful to the LiPo pak and will improve it's consumable life (cycles). to each their own of course. I have a 2s 5000mah/60C that I regularly charge at 5.0A and that has never been of issue. Regardless, I would never charge my LiPo's at any higher amps then what is recommended by the mfg'r and labeled on the LiPo. And even then... I prefer a slower, safer charge. |
07-22-2014, 10:39 AM | #7 |
^^ Excellent advice! ^^
07-22-2014, 06:02 PM | #8 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: New to lipo, need help!! Uh untrue, ill conceived, and total bullshit. But it's all good. There's really no reason to charge batteries at full throttle for a crawler anyway right?
