View Poll Results: Do you fly? | |||
Yup! | 5 | 83.33% | |
Nope! | 1 | 16.67% | |
Voters: 6. You may not vote on this poll |
07-26-2014, 02:18 AM | #1 |
Rock Stacker Join Date: Jun 2012 Location: Santa Monica/Venice
| BEC's and Discharge rates.... PLEASE HELP!!!!
OK, so I have a Zagi-33, It came with a 2100mah 25C 3S Thunder Power RC lipo. It also has a 3300kV outrunner motor powered by a 40C BEC. My question is, can I use a lipo rated at 40C with 50C bursts, with this setup? If the motor is only really constantly pulling say 25-30C, will that damage the larger C rated pack? Or is it more like, the battery can handle 1C-40C constantly, with 50C burst? I guess I'm really wondering if I can run a 40C constant with a 50C burst rating, on a BEC that is rated at 40C max. I feel like this is a rookie question, but I would rather know now, vs when this thing is up in the air and it turns into a fireball. |
07-26-2014, 08:58 AM | #2 |
| Re: BEC's and Discharge rates.... PLEASE HELP!!!!
Read this link if you haven't already done so. Understanding RC LiPo Batteries The Zagi-33 ESC is rated at 40A cont/45 burst but the motor isn't going to draw anything like that so the battery you have will be fine. I would check out some of the forums with people experienced flying the Zagi-33. You will get a lot more responses there. Also find someone local to help you learn to fly it if possible. I would also consider joining the AMA Academy of Model Aeronautics Be careful with the rotating prop. A trip to the ER will buy a whole wheelbarrow load of VP parts. |
07-26-2014, 09:49 AM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
^^^^^^ x eleventy billion! I got things that go up too
07-26-2014, 10:25 AM | #4 | |
| Re: BEC's and Discharge rates.... PLEASE HELP!!!! Quote:
07-26-2014, 12:22 PM | #5 |
Trubble hit the nail on the head. You are mixing up C and A ratings. While they both describe current, they are not interchangeable. A stands for amps. C also describes amps but can't be used as a stand alone number. You must also know the capacity of the pack to convert C to A. For instance a 2000mah 30c pack is capable of delivering 60A. It goes like this, 2000mah = 2ah. 2ah x 30c = 60a. Remember that the motor draws current. Having more current available from the battery than the motor needs keeps the packs healthy. They can't force current to a motor that isn't drawing it. The ESC must be rated to at least what the motor can draw. Again, it won't force current to the motor. It only provides what the motor is drawing. So a motor that draws 30a should be paired with an ESC that's rated to at least 30a, a little room for safety is good so a 40a ESC is a good match for a 30a motor. The battery must be able to provide the 30a to the motor but again its not healthy to require the pack to discharge at maximum capacity so a battery that can provide 40a or more would be a good choice for a 30a rated motor. I fly too. Although I fly planes and not copters, my planes spend most of their time in high alpha or hovering so I guess they get used a lot like a copter. Last edited by Calderwood; 07-26-2014 at 12:26 PM. |
07-26-2014, 07:22 PM | #6 | |
Yeah, as I look over it again, I did mean to say amps when talking about the draw from the motor. But you just confirmed what I was thinking. Thanks!!! I fly heli well, and this plane was a gift from my GF. I'm going to be taking it to burning man this year. I have been flying for many years, so I have experience with the aircraft. I'm just new to Lipo's. It's been all nitro, or Nimh stick packs for me. Thanks for all of this info everyone! I'll be sure to post the videos I capture from the flights! | |
BEC's and Discharge rates.... PLEASE HELP!!!! - Similar Threads | ||||
Noob alert: discharge/charging rates | simon170 | Electronics | 9 | 12-30-2011 08:18 PM |
2 CC BEC's or just 1 ?????????????? | slashbasher | Electronics | 1 | 08-14-2009 04:54 PM |
