08-12-2014, 07:59 AM | #1 |
Rock Crawler Join Date: Feb 2011 Location: Williston
| can anybody reccomend a HobbyKing charger?
I am looking to get an upgraded charger (finally) since I am grabbing a few batteries, and some odds and ends I thought I would ask here~ L.R. |
08-12-2014, 05:25 PM | #2 |
| Re: can anybody reccomend a HobbyKing charger?
Anyone? L.R. |
08-12-2014, 05:51 PM | #3 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
This is not a bad lil charger for the price!!! I have a few but like this one for on the go charging... TowerHobbies.com | Hitec X1+ Single Port AC/DC Charger |
08-12-2014, 06:08 PM | #4 |
RCC Addict Join Date: Jul 2008 Location: San Diego
This one is also good. A/C or DC. Up to 6 amps. Check out the video. Thunder AC680 Professional Dual-Power LiPo Balance Charger/Discharger w/ AC Adapter for 1-6 Lipo/ 1-15 Nimh + USB to PC Software |
08-12-2014, 06:18 PM | #5 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
/\ /\ /\ And it's on sale now. |
08-12-2014, 06:50 PM | #6 |
Pebble Pounder Join Date: May 2014 Location: Williston, ND
^^ the AC680 is a solid charger. Most of the chargers from China (and even most from USA brands) are all pretty much the same. If the internals are different, most run the same firmware anyway. I run 2 chargers, a Turnigy Accucel-6 50W, and a Hobbyking ECO6-10. For 2S and 3S, 50W is fine if you plan on staying at 5A or less. I charge most my batteries at higher rates when I'm in the field, so I really like the extra power of the 200W charger. If you're going over 3S, get more than a 50W charger for sure. The 2 chargers I linked to don't have power supplies. So you'll have to find your own source of 12V power. I recommend a server power supply. Super easy to convert to a 12V 47A supply, for ~$20 |
08-13-2014, 02:52 AM | #7 | |
| Re: can anybody reccomend a HobbyKing charger? Quote:
My 50W charger is plenty for charging a 4S battery at 1A. 2S 5.0A or 4S 2.5A doesn't matter, it's the same power and the same size batteries. | |
08-13-2014, 06:01 AM | #8 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
I've got 2 of the hobbyking eco 6-10 chargers. They both work great on 2s. They whine while charging 3s batteries over 6 amps or so. I even replaced the caps inside as recommended on another forum. To no avail. I can't say how the charger behaves on 4-6s but mine got so hot charging a 3s that the coil inside desoldered itself. A quick fix but this charger has issues with high amp charging. That being said I like it better that my turnigy 50watt charger and the eco 6-10 remains my main charger. +1 to converting PC power supplies !! |
08-13-2014, 06:18 AM | #9 |
sic1to, my buddy uses that charger and I think its pretty nice. The HK chargers are just so inexpensive! I will look into the 2 recommendations. L.R. |
08-13-2014, 06:50 AM | #10 | |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
08-13-2014, 07:49 PM | #11 | |
As you say, more than 50W isn't required to charge them. | |
08-14-2014, 01:08 AM | #12 | |
I think there are very few that use batteries holding more than 45VAh (2S 6Ah, 3S 4Ah or 4S 3Ah) for their crawlers. Such batteries can be charged at 1C using less than 50W. My biggest batteries hold less than 15VAh, and typical competition type batteries are 10VAh or less. Charging 100% of capacity at 1C (nominal) takes only three and a half hours. The last of those hours is just gravy topping up the last few percents. One can favourably reduce the charge time by stop charging at 4.1V/cell. The battery is then filled to ~90%, and if this method is used consistently the battery life time (number of times it can be recharged) gets about doubled compared to if charging to 4.2V/cell. Charging with a higher current will reduce the battery's life time and charging at lower current (down to 0.5C) will increase it. | |
08-14-2014, 01:32 PM | #13 |
I will see myself out of this thread. Please purchase the smallest wattage charger you can find, and charge only one battery at a time, overnight. I solidly recommended the 50W with built in power supply in my first post. It will suffice. I got by with just a 50W for years, as many people do. Last edited by Brainanator; 08-14-2014 at 01:46 PM. Reason: make it less snarky. |
can anybody reccomend a HobbyKing charger? - Similar Threads | ||||
which would you reccomend? | gofaster427 | Axial Wraith | 6 | 03-24-2013 12:45 PM |
What servo would you reccomend | Skier | Venom Creeper | 1 | 04-14-2011 07:50 PM |
Hobbyking Eco8 Balance Charger Problem | EEM-CrawlinMachine | Electronics | 5 | 01-21-2011 05:06 PM |
Reccomend me a charger! | grob23 | Electronics | 17 | 05-18-2009 06:48 PM |
