08-21-2014, 04:07 PM | #1 |
Newbie Join Date: Mar 2010 Location: titusville
| Help. Throttle controlling throttle and steering
Okay I'm pretty stumped. Everything has been perfect until today when I turn on the car I noticed the steering turned both ways full lock. I thought that was a bit odd but brought the jeep out anyways. We'll I get it outside and set it down but when i give it throttle it moves a few inches and the steering turns full lock right. I let off the throttle and the steering returns but twitches slightly. I don't see any bare wires or anything unusual so I'm guessing something internal somewhere must have gone bad. Anyone ever had a similar experience or could point me in any kind of direction?
08-21-2014, 05:13 PM | #2 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: Help. Throttle controlling throttle and steering
I have seen a defective servo do this in a 1/16 grave digger. Plug in another servo and see if it jumps when you hit the throttle.
08-21-2014, 05:24 PM | #3 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
If you run a bec (which you should) make sure it is giving proper voltage, I had a rig do something similar.
08-21-2014, 05:28 PM | #4 |
this reminds me of fault caused by water or moisture. been splashing thru puddles... or romping thru tall wet grass ? |
08-21-2014, 05:57 PM | #5 |
Sure enough I plug in a different servo and it's fine. Im still confused how it would get power from another channel though. Yes I am running a bed and I figured it would be logical for something like that to be bad than the actual servo. I've never had it in water and I keep it inside. Thank you all for the replies!
08-21-2014, 06:05 PM | #6 | |
| Re: Help. Throttle controlling throttle and steering Quote:
08-21-2014, 07:46 PM | #7 |
Well I feel kinda dumb now. I pulled the servo off with intentions to take it apart and examine it. We'll the signal wire had snagged between the frame and transmission leaving the bare wire to rub on the inside of the frame rails. Thank you again everyone for shooting some input my way.
Help. Throttle controlling throttle and steering - Similar Threads | ||||
Throttle cutting out while steering. | Tuskan | Electronics | 14 | 02-27-2014 03:01 AM |
Axial AX10 throttle stuttering without me controlling it? | dhall1591 | Newbie General | 2 | 10-20-2013 01:29 PM |
Steering no throttle | moejean | Axial SCX-10 | 9 | 03-31-2013 12:33 AM |
Steering but no throttle | 2JSC | Electronics | 16 | 05-09-2010 12:18 AM |
