09-02-2014, 07:44 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: yakima
| Cc bec
Is a 10 enough for a Hitec 7954-sh or do I need the 20 pro ?
09-02-2014, 08:01 PM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Australia
| Re: Cc bec
it will be yes just get the 10 ok
09-02-2014, 08:14 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Cc bec
Yep, ten will be fine...... And its the 7954-sh
09-02-2014, 09:21 PM | #4 |
| Re: Cc bec You will need to get a Castle Link to program the BEC voltage if you want to power the servo at 7.4 volts. The CC BEC comes set to 5.1V as the default. HeyOk has the No-Brainer BEC which you can adjust the voltage by turning a pot on the BEC and has all the wiring so all you have to do is plug it in. No Brainer BEC No Brainer BEC |
09-02-2014, 09:45 PM | #5 |
| Re: Cc bec I knew that too and typed 7945, fixed it. this might be a better choice since I don't know how to solder. Do you happen to know what the adjustment range is ? Last edited by tjcj; 09-02-2014 at 09:50 PM. |
09-02-2014, 10:59 PM | #6 |
| Re: Cc bec |
Cc bec - Similar Threads | ||||
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
