09-12-2014, 01:38 PM | #1 |
Rock Stacker Join Date: Jun 2012 Location: Santa Monica/Venice
| I need help.2 BEC's? One for winch/stearing servo, and the other for lights/receiver?
Ok folks, I'm a bit confused. I understand what a BEC is, how it works, and why we need them. What I'm trying to figure out is how many I need, and at what voltage they need to be tuned to. My plan is to (for now) run 3S 11.1v 2200 Lipo packs in my SCX10, with the AE2 ESC on a 21T 550 Titan motor. I have the Warn winch installed, and a Hitec metal gear high torque servo. I have ordered a few light bars, and crawling lights that I am going to attach to a couple of different channels on my receiver. (I run a DX6i) The larger bars are rated at 12V, and the smaller ones are rated at 6V. Can I put 2-4 small LED's on the same BEC for the winch and steering servo? Do I need a BEC for the Winch, then another for the servo? Where does the receiver get power from? Should the Receiver be on the same line as the winch / steering servo / small LED's? Sorry for the noob questions. |
09-12-2014, 01:44 PM | #2 |
| Re: I need help.2 BEC's? One for winch/stearing servo, and the other for lights/recei
There are several different ways to do it. The simplest way is to plug in the BEC directly into the Rx to power it full time. Pull the red wire from the ESC rx plug and heat shrink it. You will just be limited to the max voltage the Rx can recieve. If you want to run the lights off the 3s directly, solder two wires right at the deans plug for an extra 12v lead to power the light bars.
09-12-2014, 01:46 PM | #3 |
the 12v lights directly to the batt, I get. Should I be running multiple BEC's for the steering servo, and winch/LED's? Or would one BEC for the small LED's and the winch, and the servo be just fine?
09-12-2014, 01:54 PM | #4 |
If I only need 1, would the "10 AMP CC BEC" and the "Castle Link" be what I need? Links to what I think I need. Yes? CC BEC Castle Link |
09-12-2014, 06:59 PM | #5 | |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
| Re: I need help.2 BEC's? One for winch/stearing servo, and the other for lights/recei Quote:
if you need more than 6v on the steering servo or winch (or both) then you would want the BEC to power these directly, and leave the ESC red lead in place to power the rx and 6v leds. i tried running this way, but had issues with my servo not responding to input and like szczerba said, the 12v leds only need to be tapped off the battery leads. a BEC for these would only prevent a fully charged 3s lipo from blowing the lights if they cant handle the extra little bit of voltage Last edited by nharkey85; 09-12-2014 at 07:07 PM. | |
I need help.2 BEC's? One for winch/stearing servo, and the other for lights/receiver? - Similar Threads | ||||
Savox 1256tg servo issues. Winch in/out, lights flicker ?? | Hoosierdady | Electronics | 3 | 04-26-2014 04:13 PM |
traxxas stampede stearing servo | losiminicrawler | Newbie General | 0 | 10-06-2009 08:59 PM |
powering a 3 racing winch , servo & receiver | Badd | Electronics | 1 | 07-28-2009 05:31 AM |
Stearing servo going CRAZY ! Flashing red light !!! Please help | 86 Iroc | Losi Mini-Rock Crawler | 4 | 04-05-2009 10:10 AM |
Wiring 2 bec's, one for each servo | rockmike | Electronics | 19 | 04-03-2008 10:57 AM |
