NOvak HV Controller w/ BL crawler can???? I really like my HV4.5 but it's I feel it's to much for the TXT. I also love the HV Controller because you can use a dual batt. setup or single and the 6.0V/3.0amp BEC. I was noticing other ESC's and they are usually 6V/1.5amp's. Do you think I can swap the 4.5 motor for the 18.5 Crawler one?:idea: It says it can only handle 4-6 Cells, and I only run 2S2P 7.4V lipo pack at a time. So it should be able to handle it. What do you guys think? |
Since no one's responding how about the MambaMax 4600 Package. It's brushless and I've used Mamba's before. I love all the programming features and if you look at the pic, everything is adjustable. Drag brake, Punch Control, Brake Amount, Brake Reverse Type. This should work. http://www.castlecreations.com/image...ax/Max-CL2.jpg You can also adjust the throttle and brake curve. |
You could use the crawler can with the HV controller. It would be pretty good. With the mamba system you will need an outrunner to get crawler control and performance. |
The Mamba setup will be a bit powerful. You'll be fine with your 2S2P and the crawler motor. The Mamba setup is $187, if the crawler motor is close or more than that I would consider the Mamba. |
Ordered the crawler motor and Novak's new Lipo LVC for 2S. I'll let you know how it handles. |
