12-02-2006, 06:21 PM | #1 |
Rock Crawler Join Date: Mar 2006 Location: Benson,NC
| esc????
Ok running 2 tekin rebel 2 esc's 1 6 cell battery pack 3700 gp,front motor has plenty of power back motor very slow.The motors are 65 turn integy lathes.Why is this?Had the same setup but with different esc's and 55 turn integys had no problem what do you think could be the problem?Should i try a pack front and rear?Please any help is appreciated. Thanks,Nathan
12-02-2006, 06:24 PM | #2 |
RCCRAWLER TEAM DRIVER Join Date: Jun 2005 Location: Voiding warranties
I had a rear 65 turn go bad not to long ago the front would work but the rear would not and since the power goes to the back first I knew there was power so I replaced them both.
12-03-2006, 04:37 AM | #3 |
well i am running a 4 channel radio so they run on diffent channels,and the motors are brand new?
12-03-2006, 05:10 AM | #4 |
I have had new stuff that was broke. It happens. Running 2 packs should change anything but runtimes. I would think. But I'm not to great with that part of RC's....
12-03-2006, 05:22 AM | #5 |
OK i just tried running the truck the rear sucks.It has no ballz at all,I unplugeg the motor and hooked battery straight to the motor and it worked fine?Now i am really lost i will put a 6 cell on front and one on back thats the only thing i can think of.
12-03-2006, 05:27 AM | #6 |
How do you have you motors wired? You might have a bad wire robbing your power. Might change the wires to the rear motor before adding the weight. Is these on a Super with 40's wheels or a 2.2? Have any pic's of the set up?
12-03-2006, 05:38 AM | #7 |
12-03-2006, 07:47 PM | #8 |
So when you hooked the battery straight to the motor you bypassed the esc? Maybe the esc is the culprit? Is it programable? If so, are both esc's programed the same? Just a thought.
12-03-2006, 08:59 PM | #9 |
Pebble Pounder Join Date: Sep 2006 Location: SW Charlotte
emutt switch the escs front and rear and see if the problem moves also... maybe a bad esc
12-03-2006, 10:10 PM | #10 |
I fixed the problem i just put a 6 cell on the back and one on the front no more stall at all!!! Thanks for everyones ideas and info Should have a vid of this thing shortly so keep an eye out.
