11-20-2014, 07:50 PM | #1 |
Newbie Join Date: Oct 2014 Location: springfield
| separate battery to power winch
The title says it self I was curious if you could use a small separate batter to power a winch system on an axial wraith? If so what size lipo would I use? cause I'm using a venom 5000mah 2cell an I would like to leave the power that has to my truck an use the other battery to power the winch, is that possible?
11-20-2014, 09:23 PM | #2 |
Pebble Pounder Join Date: Apr 2013 Location: traverse
| Re: separate battery to power winch |
11-21-2014, 11:17 AM | #3 |
That's what I was thinking but then would I need to run a. Bec for the mini 2s lipo to control the power output of the battery?
11-21-2014, 12:00 PM | #4 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
I've been running a 350 3 cell through a micro sidewinder for over a year now , Works great , has low volt cutoff that iv'e never hit and the brake keep the rig put however steep the hill is.
11-24-2014, 04:27 PM | #5 |
I bought a venom 2100mah 3 cell the other day plus ordered a new winch just in case I burn one out when I try this an I do have the castle bec as well so this thanksgiving weekend we shall give it a shot
11-27-2014, 05:50 PM | #6 |
Newbie Join Date: Nov 2014 Location: reading area
I have the warm winch with the wireless control unit. I've never had it connected to anything but it's own battery directly connected. I started using a 25c 4000 mah 2s venom. Then switched to a 1800 mah 2s venom, now an using a 60c 2200mah 3s turnigy. All you should need to do is check your winch manufactures recommended voltage. The warn from rc4wd is 3s capable. Some others are only 2s like my son's integy, which he also runs of of direct battery power same as me.
separate battery to power winch - Similar Threads | ||||
Separate light battery set up? | jwall046 | Newbie General | 10 | 07-04-2014 11:59 PM |
BEC or separate battery | ed701 | Newbie General | 16 | 03-24-2013 06:13 PM |
Separate power for RC4WD LED light bar | ethernectar | General Scale Talk | 6 | 10-02-2012 09:18 PM |
Purpose of Separate Power Supply? | alexchen86 | Electronics | 7 | 12-22-2011 04:55 PM |
Howdo you hook-up a separate battery for the servos | Azcats1 | Electronics | 2 | 01-27-2006 08:45 AM |
