12-24-2014, 04:18 AM | #1 |
Newbie Join Date: Jan 2014 Location: Thorsby
| Mmp question and cc bec question.
First off my sensor wire broke while running. I keep trying to run it (didn't know at the time) will that burn up a mmp? Next I changed out the esc now my bec is back feeding when esc starts up. Bec is wired strait to the servo same as I run all my stuff. Just curious. I know I gotta have a new esc but the bec don't really know. Sent from my iPhone using Tapatalk |
12-24-2014, 09:47 AM | #2 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| Re: Mmp question and cc bec question.
Isolate your bec and put a volt meter on it to make sure its good. Also return the negative wire to the rx.
12-24-2014, 11:28 AM | #3 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Mmp question and cc bec question. Quote:
12-24-2014, 11:39 AM | #4 | |
Bec is gets its power off esc batt leads then nothing but the signal wire to rx from servo. Then bec Is hooked to hot and ground of servo. By back feeding when you turn the car on the servo would jump with the beeps of the mmp. I've got the same set up on all my rigs with no probs. I think moisture was the problem. With saying that was running in wet grass. Which I've done several times with others. It's on a yeti and I had the bec in box to right of the motor. (It lets a lot of water in) LOL. Sent from my iPhone using Tapatalk | |
12-24-2014, 02:21 PM | #5 |
Yea sounds as if you have water issues with the esc that's causing quite a bit of problems. I would pull and seperate all components and start from checking each one. Broken sensor wouldn't be the cause..... But water into the esc would be.... Also should have been added into origional post. Bec is pretty simple unit as where it either works or it does not. It's just a basic adjustable voltage regulator so to speak. With that said I would see if putting the esc in a bowl of rice or dis assembling it and drying out fixxes its issue. |
12-24-2014, 03:50 PM | #6 | |
Yes I should have mentioned it in the first post. Everything is installed and back working properly. Thanks for the responses. Kinda bitter sweet I wanted rx8 but didn't want to (have) to buy one!! Sent from my iPhone using Tapatalk | |
12-24-2014, 04:38 PM | #7 |
Yep, watter will make electronics do silly things. Time to set up system to be water proofed and move forward. |
Mmp question and cc bec question. - Similar Threads | ||||
got a MMP question | kgb424 | Electronics | 4 | 10-16-2014 09:15 AM |
MMP Question | Jake Ewing | Electronics | 4 | 12-04-2013 04:53 PM |
MMp question | mark32 | Electronics | 4 | 05-29-2013 05:20 PM |
MMP question?? | hatefulboy | Electronics | 9 | 09-16-2012 11:48 PM |
MMP question? | dAng! XJ | Axial Wraith | 3 | 11-17-2011 08:45 AM |
