12-24-2015, 04:36 PM | #21 |
Quarry Creeper Join Date: Jul 2015 Location: Hanover
| Re: Arduino based scale LED lighting - Wraith
While I'm waiting for parts to manifest for my CJ-5 build, I decided to work on the lights for my XJ. Rather than make a new post, I thought it best to just add to this one. Awesome work by the OP!!! I printed some light buckets, and re-worked my sketch. If anyone wants the code, it's below. some caveats.... the Arduino (upon power-up) looks to input 4 (throttle) and calls whatever signal it sees as "center channel," so if you get unexpected behavior, try cycling the power... there are no turn signals. We don't use them. Hazzards (4 ways) come on after 20 seconds idle. the brake lights and rear "turns" are not connected, neither physically nor electronically. That is a different program...(just ask) lots of blinky stuff happens if the Arduino suspects the signal is "out of bounds" with the throttle channel. Brake lights work all three modes. Mode 1; only brake lights. Mode 2; Brakes and markers. Mode 3, Brakes, markers, and Headlights. Headlights fade when they're turned off... Hazzards work in all three modes after 20 seconds, automatically. (as stated before) If you don't have a three (or four) channel Rx, just "comment out" that input, and select your mode manually... This is based upon a GikFun Pro Micro. 5v Arduino. The Arduino cannot power the LED's directly. You must use a resistor. Your mileage will vary depending upon your choice of LED's. because of the forward Voltage drop of my LED's I'm using two outputs for the headlights. 10 and 3. one output for the front two marker/flashers, 6 one output for the rear flashers, 9 one output for the brakes, 5 I've also designed a box in which to stuff everything. Ask me for the .STL if you have a 3d printer. I'm thinking of selling the light buckets for the XJ, but I won't get into that here... 6 wires out. 4 wires in. (3 if you don't want to control the modes) Any questions, just ask. You might be asking the same question someone else is too afraid of asking... |
12-24-2015, 04:39 PM | #22 |
as promised....(don't laugh too hard... Code: int rfhl = 10; // pin assignments for headlights int lfhl = 3; int front = 6; //pin assignments for front markers int brake = 5; //brake lights int rear = 9 ; // pin assignment for rear markers int modePin = 18; //comment this out for 2 ch operation int modeValue; //for manual selection enter "= 1000", "=1500", "=2000" before the semicolon int dimVal = 20; //placeholder for dimmer value int blinkVal = 350; //interval for hazzard light blink int brite = 255; //brake light "brightness" int dim; //brake light dim value int db; //deadband center unsigned int centered; //is channel centered ? int ch1 = 4; //pin assignment input unsigned int pulseVal; unsigned long currentMill; //inactivity timer unsigned long prevMill; //inactivity timer unsigned int timerMet; //inactivity timer const int timerCon = 20000; //hazzard delay time constant unsigned long timerVal; //inactivity timer unsigned int dbLO; //deadband width LO unsigned int dbHI; //deadband width HI int hlState; //used for dimming the headlights 1 is on. int fadeValue; int noSignalTag; void setup() { //not much to see here, run once and go away... pinMode (ch1, INPUT); //throttle input monitor pinMode (modePin, INPUT); //mode selector pinMode (brake, OUTPUT); pinMode (rfhl, OUTPUT); pinMode (lfhl, OUTPUT); pinMode (front, OUTPUT); pinMode (rear, OUTPUT); Serial.begin (9600); db = pulseIn (ch1, HIGH); dbLO = (db * .98); //if the center position isn't wide enough try adjusting dbHI = (db * 1.02); // these constants to .9 and 1.1 } void loop() { currentMill = millis(); //timer pulseVal = pulseIn (ch1, HIGH); modeValue = pulseIn (modePin, HIGH); Serial.print ("deadband "); //debug stuffs Serial.println (dbLO); Serial.print ("PulseVal "); Serial.println (pulseVal); Serial.print ("centered "); Serial.println (centered); Serial.print ("prevMill "); Serial.println (prevMill); Serial.print ("timerVal "); Serial.println (timerVal); Serial.println ("fadeValue"); Serial.println (fadeValue); timerVal = (currentMill - prevMill); mode(); //mode check if ((pulseVal > 2500) || (pulseVal < 700)) { //if the signal is out of bounds... noSignal (); } else if ((pulseVal >= dbHI) || (pulseVal <= dbLO)) { //cecking for center centered = 0; timerMet = 0; prevMill = currentMill; analogWrite (brake, dim); noSignalTag = 0; } else if ((timerCon >= timerVal) && (centered == 1) && (noSignalTag == 0)){ timerMet = 1; } else if ((timerMet = 1) && (centered == 1)){ //set "hazards" routine if centered too long hazzardRoutine (); } else { centered = 1; analogWrite (brake, brite); } } void hazzardRoutine(){ hlRoutine ();//turn your truck off or drive it!!! analogWrite (front, brite); analogWrite (rear, brite); //change to "(brake, brite)" to use combined brake/hazzard delay (blinkVal); analogWrite (front, dim); analogWrite (rear, LOW); //change to "(brake, dim)" to use combined brake/hazzard flash delay (blinkVal); return; } void noSignal () { //so you know if there's no signal... noSignalTag = 1; digitalWrite (brake, brite); digitalWrite (front, brite); digitalWrite (rear, LOW); analogWrite (rfhl, brite); analogWrite (lfhl, dim); delay (50); digitalWrite (brake, LOW); digitalWrite (front, LOW); digitalWrite (rear, brite); analogWrite (rfhl, dim); analogWrite (lfhl, brite); delay (50); digitalWrite (brake, brite); digitalWrite (front, brite); digitalWrite (rear, LOW); analogWrite (rfhl, brite); analogWrite (lfhl, dim); delay (75); digitalWrite (brake, LOW); digitalWrite (front, LOW); digitalWrite (rear, brite); analogWrite (rfhl, dim); analogWrite (lfhl, brite); delay (100); return; } void mode () { //ch3 input to select operating mode if (modeValue < 1400) { //MODE 1 only brake lights dim = LOW; hlState = 0; hlRoutine (); analogWrite (front , LOW); analogWrite (rear , LOW); } else if (modeValue > 1700) { //MODE 3 headlights + parking lights hlRoutine (); dim = dimVal; hlState =1; fadeValue = brite; analogWrite (rfhl , brite); analogWrite (lfhl , brite); analogWrite (front , dim); analogWrite (rear , LOW); //change to "dim" if you want them on as parking lights } else { //MODE 2 parking lights (no headlights) dim = dimVal; hlRoutine (); analogWrite (rear , LOW); //change to "dim" ifyou want them on as parking lights analogWrite (front , dim); if (hlState == 1) { hlRoutine (); } } } void hlRoutine () { if ((fadeValue >= 1) && (hlState || 1)){ analogWrite (lfhl, fadeValue); analogWrite (rfhl, fadeValue); fadeValue = (fadeValue - 30); } else { digitalWrite (lfhl, 0); digitalWrite (rfhl, 0); fadeValue = 0; return; } } |
01-26-2016, 10:14 AM | #23 |
I'm trying real hard not to HiJack this thread...but I feel it worthy of mention that I've re-written the code about four times since the above post. There is added functionality, and most of the delay timers have been removed. This is important because it speeds up the program, makes it more reliable, and more responsive than my previous version. If there is any interest at all, PM me (so we don't clutter this thread) and I'll share the code. Or, if there's enough interest, I'll do a build thread/instructions set, as my schematics and the OP do not match. Thanks again to the OP for tolerating me!! Cheers, |
01-26-2016, 11:18 AM | #24 | |
Awesome little project! Thanks for sharing. I'd love to know how to program Arduino. Quote:
02-02-2016, 05:29 PM | #25 |
Quarry Creeper Join Date: Oct 2014 Location: East
I'm not sure how I missed about 6 replies since December. Sorry for not posting back. Feel free to post here. I think it's a good resource to keep it all together. I don't feel your hijacking anything. I'm in the middle of a rewrite, taking it to the next level. I'm dumping all the blocking code in lei of creating an actual loop. This means I'm am using interrupts to read and write pins. It will allow for multiple functions to occur and not wait for a function to finish. Translated, I can use my winch and change other functions without any delay in the code. Example: This was the Arduino controller I built for SCX10 Chevy. Full signals, tail lights. Everything I showed previously in this thread. What I added was a 6 channel receiver (of which I am using 5) for Lightbar brightness and transmitter controlled winch. I haven't finished the rewrite for this yet because the interrupts are also tide to pins that I am using. So, for a software update I have to rewire or replace the board with a revision 2. I am just starting to get back into winter building and hope to route a PCB sometime in the next month. I can dump the code I have written though it is far from finished. I'm using calls outside the Arduino Library to access Interrupts and can post the resources on where I found the info Last edited by drzoo2; 02-02-2016 at 05:47 PM. |
06-18-2019, 09:20 AM | #26 |
Rock Stacker Join Date: May 2013 Location: Sweden
Is any one using this code anymore ? I am just started with Arduino and I wonder if someone has done some updating to this code, I would like it
06-18-2019, 10:04 AM | #27 | |
| Re: Arduino based scale LED lighting - Wraith Quote:
Sent from my HTC U11 using Tapatalk | |
06-18-2019, 11:06 AM | #28 |
Thanks for your reply ! Like i wrote I am new to Arduino but done som html and php programming. I am building a Scania truck and want to have some more lights then on my crawlers. Hope you have time to help me. The mode switch is it 2pos switch? I would like to have it on a 3pos switch and have these functions. 0=off 1=Running lights 2= Running lights and markers. I also want a switch for Hazzard light. Just a 2pos switch. The last thing is reversing lights. Done some editning in the code and also added one input for 2pos swtich and one output for highbeam. Would really appreciate any help. One simple thing I assume for any that can code,is the code for Input CH2 and turn ocf on Highbeam Dont need all code just pieces I can copy/paste to more functions Here is the code now Code: int rfhl = A0; // pin assignments for headlights int lfhl = A1; int front = A2; //pin assignments for front markers int brake = A3; //brake lights int rear = A4; // pin assignment for rear markers int highb = A5; //Highbeam int modePin = 3; //comment this out for 2 ch operation int modeValue; //for manual selection enter "= 1000", "=1500", "=2000" before the semicolon int dimVal = 20; //placeholder for dimmer value int blinkVal = 350; //interval for hazzard light blink int brite = 255; //brake light "brightness" int dim; //brake light dim value int db; //deadband center unsigned int centered; //is channel centered ? int ch1 = 9; //Throttle pin assignment input int ch2 = 10; // Radio 2pos Highbeam unsigned int pulseVal; unsigned long currentMill; //inactivity timer unsigned long prevMill; //inactivity timer unsigned int timerMet; //inactivity timer const int timerCon = 20000; //hazzard delay time constant unsigned long timerVal; //inactivity timer unsigned int dbLO; //deadband width LO unsigned int dbHI; //deadband width HI int hlState; //used for dimming the headlights 1 is on. int fadeValue; int noSignalTag; void setup() { //not much to see here, run once and go away... pinMode (ch1, INPUT); //throttle input monitor pinMode (modePin, INPUT); //mode selector pinMode (brake, OUTPUT); pinMode (rfhl, OUTPUT); pinMode (lfhl, OUTPUT); pinMode (front, OUTPUT); pinMode (rear, OUTPUT); pinMode (ch2, INPUT); Serial.begin (9600); db = pulseIn (ch1, HIGH); dbLO = (db * .98); //if the center position isn't wide enough try adjusting dbHI = (db * 1.02); // these constants to .9 and 1.1 } void loop() { currentMill = millis(); //timer pulseVal = pulseIn (ch1, HIGH); modeValue = pulseIn (modePin, HIGH); Serial.print ("deadband "); //debug stuffs Serial.println (dbLO); Serial.print ("PulseVal "); Serial.println (pulseVal); Serial.print ("centered "); Serial.println (centered); Serial.print ("prevMill "); Serial.println (prevMill); Serial.print ("timerVal "); Serial.println (timerVal); Serial.println ("fadeValue"); Serial.println (fadeValue); timerVal = (currentMill - prevMill); mode(); //mode check if ((pulseVal > 2500) || (pulseVal < 700)) { //if the signal is out of bounds... noSignal (); } else if ((pulseVal >= dbHI) || (pulseVal <= dbLO)) { //cecking for center centered = 0; timerMet = 0; prevMill = currentMill; analogWrite (brake, dim); noSignalTag = 0; } else if ((timerCon >= timerVal) && (centered == 1) && (noSignalTag == 0)){ timerMet = 1; } else if ((timerMet = 1) && (centered == 1)){ //set "hazards" routine if centered too long hazzardRoutine (); } else { centered = 1; analogWrite (brake, brite); } } void hazzardRoutine(){ hlRoutine ();//turn your truck off or drive it!!! analogWrite (front, brite); analogWrite (rear, brite); //change to "(brake, brite)" to use combined brake/hazzard delay (blinkVal); analogWrite (front, dim); analogWrite (rear, LOW); //change to "(brake, dim)" to use combined brake/hazzard flash delay (blinkVal); return; } void noSignal () { //so you know if there's no signal... noSignalTag = 1; digitalWrite (brake, brite); digitalWrite (front, brite); digitalWrite (rear, LOW); analogWrite (rfhl, brite); analogWrite (lfhl, dim); delay (50); digitalWrite (brake, LOW); digitalWrite (front, LOW); digitalWrite (rear, brite); analogWrite (rfhl, dim); analogWrite (lfhl, brite); delay (50); digitalWrite (brake, brite); digitalWrite (front, brite); digitalWrite (rear, LOW); analogWrite (rfhl, brite); analogWrite (lfhl, dim); delay (75); digitalWrite (brake, LOW); digitalWrite (front, LOW); digitalWrite (rear, brite); analogWrite (rfhl, dim); analogWrite (lfhl, brite); delay (100); return; } void mode () { //ch3 input to select operating mode if (modeValue < 1100) { //MODE 1 only brake lights dim = LOW; hlState = 0; hlRoutine (); analogWrite (front , LOW); analogWrite (rear , LOW); } else if (modeValue > 1900) { //MODE 3 headlights + parking lights hlRoutine (); dim = dimVal; hlState =1; fadeValue = brite; analogWrite (rfhl , brite); analogWrite (lfhl , brite); analogWrite (front , dim); analogWrite (rear , LOW); //change to "dim" if you want them on as parking lights } else { //MODE 2 parking lights (no headlights) dim = dimVal; hlRoutine (); analogWrite (rear , LOW); //change to "dim" ifyou want them on as parking lights analogWrite (front , dim); if (hlState == 1) { hlRoutine (); } } } void hlRoutine () { if ((fadeValue >= 1) && (hlState || 1)){ analogWrite (lfhl, fadeValue); analogWrite (rfhl, fadeValue); fadeValue = (fadeValue - 30); } else { digitalWrite (lfhl, 0); digitalWrite (rfhl, 0); fadeValue = 0; return; } } Last edited by quart; 06-18-2019 at 11:34 AM. Reason: Adding code |
06-20-2019, 11:32 AM | #29 |
It's been a long time since I played with this... The I remember it... AUX1 fed an input to control the lighting mode. (Brakes only, parking lamps, headlights+parking lamps) There was a Y cable that carried the signal from CH1 (throttle) that controlled the brake and reverse lights. There was a simple routine that ran at startup, where the Arduino "learns" which way "forward" is, in order to reference "when to use reverse" lights. The four-ways (hazard lamps) were on an "inactivity" timer and came on after 20 seconds of "no input" from the Tx. That timer was cancelled and reset every time an input was triggered. The rest was all just "cosmetic" stuff, like making the headlights turn off slow (like an incandescent bulb does). If you would like more help, let me know. I can help with my code build, but probable not anyone elses. |
06-20-2019, 12:21 PM | #30 |
Awesome stuff! Keep it up guys.
06-20-2019, 12:23 PM | #31 |
If you are looking for something already built, check out my stuff |
Arduino based scale LED lighting - Wraith - Similar Threads | ||||
Led lighting | craddock35 | Electronics | 2 | 07-13-2013 02:29 PM |
LED Lighting Help | juswin24 | Electronics | 7 | 09-03-2012 07:55 PM |
LED Lighting? | Drey | Electronics | 5 | 01-19-2010 03:17 PM |
Scale seats and LED roof lighting | washracer_11 | Newbie General | 12 | 12-08-2008 05:43 PM |
