01-29-2015, 11:11 AM | #1 |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
| 2200 mAh lipo
So, I'm coming to the end of my SCX10 based China JK build, and as anyone who's followed a couple of these builds, knows there's very little space for much of anything under there, and because I'm limited to such little space, it seems the only battery I'll be able to use is a tiny 2200mAh 3S lipo. I realize there is also a 2S version around this size as well, which is even smaller if I'm not mistaken . Now I'll be the first to admit, as much as I've tried to grasp the battery number lingo, I still don't always get it. I do understand the difference in between 2S and 3S, and the voltage associated with both. My primary concern with such a small battery is, how short will my run times be? Is it even worth using such a battery to begin with? This is simply a trail truck and will be used for some light crawling and trail runs. I appreciate any insight any one can offer. I know this may seem like sort of a noob question, but I'm at a loss and a bit disgusted with this atm ;) Has anyone used such a small battery similar to this in their rig before? Here's a link to the build. A'nudder China JK build Last edited by tokdl; 01-29-2015 at 11:15 AM. |
01-29-2015, 11:35 AM | #2 |
| Re: 2200 mAh lipo
Some pics from farther away would help.. You could always look into running a couple smaller packs, like saddle packs. Run time should be atleast half hour on a 2200mah 3s.. Depending on motor, gearing, throttle finger.. |
01-29-2015, 11:38 AM | #3 |
| Re: 2200 mAh lipo Thanks for the response. Sorry about the poor photos, I snapped those literally on my way out the door to work. I am currently looking into others that have made SCX10 side saddle mounts atm. That is a good idea!
01-29-2015, 11:44 AM | #4 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| Re: 2200 mAh lipo
I have ran 2200 2S packs for a few years and get 1-1/2 to 2 hours trail time from them. I have a couple 2200 3S packs that I've not ran as much, but at least the same run time. I use 3-4 batteries for an all-day GTG when I run them. The largest battery I own is a 2650 3S. Smaller batteries take-up less space and save a little weight. Ain't no shame in changing batteries every few hours while enjoying the rocks.
01-29-2015, 11:50 AM | #5 | |
| Re: 2200 mAh lipo Quote:
01-29-2015, 12:02 PM | #6 |
| Re: 2200 mAh lipo
I can get an hour out of a 1100 2S battery and 35 turn motor in a lightweight SCX.
01-29-2015, 12:11 PM | #7 | |
Thanks for the advice guys! Last edited by tokdl; 01-29-2015 at 12:28 PM. | |
01-29-2015, 06:36 PM | #8 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: 2200 mAh lipo
HK USA West has 'em for a mere $6 right now, BTW; that's a steal at 40% off the already cheap price. I ordered 3 more from the link in my sig below. Last edited by StomperCrawler; 01-29-2015 at 06:37 PM. Reason: Link |
01-29-2015, 06:42 PM | #9 |
| Re: 2200 mAh lipo |
01-29-2015, 09:06 PM | #10 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: 2200 mAh lipo
I was getting about 45 min to an hour with my 2200's. But I had a 55T that was at full throttle a lot too.
01-31-2015, 07:19 AM | #11 |
| Re: 2200 mAh lipo
I have a handful of Turnigy 2200 40C 2s softcases that I run in my go-slow fleet. I like the reduced weight over my 4000mah hardcase packs for my go-fast fleet. Runtimes range from 1/2 hour in a 17.5 Brushless powered Twin Hammers snow bashing at mostly WOT to 1 1/2 hours in a 27 turn powered SCX trail riding and crawling. The only thing to consider for some mega powered brushless motors is if the smaller capacity batteries are able to keep up the the amperage spikes and overall increased draw. For anything that's 13.5 brushless or less powerful I wouldn't be terribly concerned about my 40C 2200mah packs keeping up. I would not run them in my Wraith with something like a Pro4 though. |
01-31-2015, 08:49 AM | #12 |
| Re: 2200 mAh lipo
I'm rather interested to use this just to see what it's like. Turns out it looks like I'll be able to tightly fit a 3300 mAh Along the rear frame rails. I truly appreciate all the information it certainly helped! |
01-31-2015, 11:37 AM | #13 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: 2200 mAh lipo
30 minutes out of a 850mah pack. Normal trail running, a few bursts of speed.....
01-31-2015, 03:09 PM | #14 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: 2200 mAh lipo
30mins on 10lb c3 rig.......... On the throttle busts every couple mins. 4 wheel steering action And couple 12 volt winches 2200 mah 50c |
01-31-2015, 03:35 PM | #15 |
| Re: 2200 mAh lipo
It very well may be worth it for the savings in weight. My trail runs usually don't last for more than a couple hours tops.
02-01-2015, 04:46 PM | #16 |
Newbie Join Date: Mar 2010 Location: Maryville
| Re: 2200 mAh lipo
what is best discharge to use 20c 30c 40c to use if i was to buy some 2200 mAh 2S?
02-01-2015, 06:15 PM | #17 |
| Re: 2200 mAh lipo |
02-06-2015, 06:15 PM | #18 |
Rock Stacker Join Date: Sep 2014 Location: korea
| Re: 2200 mAh lipo |
02-06-2015, 08:01 PM | #19 |
| Re: 2200 mAh lipo |
02-08-2015, 03:24 PM | #20 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
| Re: 2200 mAh lipo
That battery gets 2 thumbs up for me!!!
2200 mAh lipo - Similar Threads | ||||
Charger recommendation for 11.1 lipo 2200 mAh | NerdDoc | Electronics | 9 | 12-29-2014 11:08 PM |
