03-30-2015, 11:13 PM | #1 |
Newbie Join Date: Mar 2015 Location: Bremerton
| CC 2200 runs safe on 6s but T8 2000 will only run 4s?
Can someone explain why there is such a huge difference here in max voltage. I get the tekin is sensored, is that enough to require a 7 volt drop?
03-31-2015, 12:55 AM | #2 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
| Re: CC 2200 runs safe on 6s but T8 2000 will only run 4s?
Max RPM is primarily dictated by the rotor size / construction technique. Maybe the Tekin rotor is bigger or is more fragile in high RPM application. |
CC 2200 runs safe on 6s but T8 2000 will only run 4s? - Similar Threads | ||||
Run time on 3s 2200? | Beej | Axial Wraith | 0 | 01-09-2012 04:47 PM |
3s 11.1 20c 2200 | Jstalker | Electronics | 6 | 01-07-2011 07:47 PM |
Run times on the RTR AX10 and a lip 2000` | RickM | Axial AX-10 Scorpion | 10 | 02-05-2010 02:30 AM |
Battery with low run times. its supposed to be a 4200 mah but it runs like a 1500 mah | tylinens69 | Electronics | 20 | 10-20-2009 08:46 PM |
wallmart gun safe...Really safe? | xxizzer421xx | Chit Chat | 10 | 10-11-2007 02:42 PM |
