05-15-2015, 06:20 AM | #1 |
Rock Stacker Join Date: Sep 2013 Location: Walsall, UK
| Cooked a Novak... what next?
I've managed to cook my Rockstar 35t motor so im looking for something to replace it with now. I still have the Eiger Pro ESC which is fine so looking for suggestions for a motor to go with it. Will be run on 2S lipo and im thinking something around 35t as i liked the mix of torque and wheel speed from the 87\22t 48p gearing im running. Was thinking maybe Holmes or Tekin but not sure which would be best... this is for a SCX10 btw... Thanks in advance, Nige Last edited by n_d_fox; 05-15-2015 at 06:23 AM. |
05-15-2015, 06:45 AM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Cooked a Novak... what next?
Holmes would be my recommendation, get it waterproof too for extra safety.
05-15-2015, 06:56 AM | #3 |
I'm guessing you cooked your motor from too much gearing, back the pinion down several teeth. I run a pretty strong brushless motor in my truck and I'm only at 13/56 using 32P gears (about 20/87 in 48P). If you dial the gearing back, you can change to a 27-30T motor on 2S or stick with a 35T and run 3S to get your wheelspeed back. The same 35T motor on 3S with 87/16 gearing would have a little more top end speed as your current setup, better low speed control, and run cooler. I would personally take the 3S route because a wise man once said "gear down, volt up." As for motors, I picked up a Holmes Torquemaster Expert for my latest build. It is a very good motor that doesn't break the bank. |
05-15-2015, 07:32 AM | #4 |
Quarry Creeper Join Date: Mar 2012 Location: I can see Canada from my house!
As svt923 said, it's very likely that it was your 4:1 gearing that killed your motor. Bring it to 5:1 and go 3s. Maybe even jump to 45T.
05-15-2015, 04:10 PM | #5 |
Thanks guys, appreciate the help
05-15-2015, 04:11 PM | #6 |
| Re: Cooked a Novak... what next? |
05-16-2015, 09:39 AM | #7 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
He probably meant the esc...not the motor And I agree about the previous posts on your gearing....drop your pinion down to a 17 or so....or you'll burn up your next motor too. Keep checking your temps when you first try it.... |
Cooked a Novak... what next? - Similar Threads | ||||
ESC cooked? newbe | Murphybonez | Electronics | 6 | 01-03-2012 01:05 PM |
Cooked esc | Tyler-brown | Redcat Crawlers | 5 | 12-19-2011 06:20 PM |
cooked Tekin 35T | BigSki | Electronics | 8 | 11-15-2010 04:24 PM |
POORMANS HIGH LIFT ***DONE***and COOKED!! | twisted84toyota | 1.9 Scale Rigs | 33 | 02-08-2007 03:15 AM |
Cooked bearing | RD400 | Chit Chat | 8 | 09-18-2006 10:24 PM |
