Thread: Axial Wraith AE-2 ESC problem
Old 06-24-2015, 07:52 PM   #1
Default Axial Wraith AE-2 ESC problem
My wraith's ESC constantly goes into program mode without holding throttle on transmitter. Installed CC BEC Pro 2 weeks ago and everything has been working great until now. I triple checked throttle setting to make sure they are set at zero. I even checked all connection between reciever, ESC and CC BEC Pro. Any ideas?
johnno2011 is offline   Reply With Quote
Old 06-24-2015, 08:41 PM   #2
Default Re: Axial Wraith AE-2 ESC problem
Have you tried re binding the radio to the receiver?
novarider is offline   Reply With Quote
Old 06-24-2015, 09:05 PM   #3
Yes but same result.
Old 06-25-2015, 01:11 AM   #4
Also check your trim and subtrim (if your radio has that) settings to make sure they are zero'd.
Solitaire is offline   Reply With Quote
Old 06-25-2015, 08:36 AM   #5
Yep triple checked that.
Old 06-25-2015, 08:43 AM   #6
What radio are you using? does it have a 50/50 and 70/30 setting on the trigger?
Try a different radio. If your esc is constantly going into program mode, it is sensing a full throttle input from your radio. If a different radio doesn't work remove the BEC and try again. Still not working, probably the ESC.
redsawacs is offline   Reply With Quote
Old 06-25-2015, 09:14 AM   #7
I only have the factory ax3 2 channel radio that comes with it.
Old 06-25-2015, 01:09 PM   #8
Then, it is highly feasible that the radio is giving a false signal but it is hard to say unless you start isolating parts.
Old 06-25-2015, 01:20 PM   #9
do yo have a spare servo you can try? A bad servo can cause all sorts of stupid problems. Mine would randomly shut the motor down but would still have steering.
Zrock is offline   Reply With Quote
Old 06-25-2015, 06:09 PM   #10
No I don't have a spare servo. Got back into rc 2 months ago and money has been fight.
Old 06-25-2015, 07:26 PM   #11
Just un plug the servo and see if it fixes it.
Old 06-25-2015, 07:37 PM   #12
Just tried without servo and still goes into setup mode
Tags
ae-2, axial, bec pro, esc, wraith
Axial Wraith AE-2 ESC problem - Similar Threads
Wraith Transmitter/reciever/esc? Problem Bodie Axial Wraith 6 05-27-2014 10:09 PM
Wraith rtr esc problem? fish-hunter Axial Wraith 11 07-13-2013 06:07 AM
Wraith esc problem uncle-speed Axial Wraith 11 10-28-2011 07:06 PM
Problem with wraith esc. Erbing Electronics 5 08-06-2011 06:36 PM
Axial AE-1 esc problem super mud Electronics 3 02-20-2010 12:32 AM
