07-10-2015, 04:18 AM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: Connecticut, USA
| Help with DX4s and FXR?
Hey guys, I looked on here for similar situation and couldn't find one, So please forgive me if this has been answered elsewhere, I couldn't find an answer, but I did look... First... Heres my Hardware: Battery = 3S 11.1V 3000ma Motor = Tekin 45T Brushed ESC = Tekin FXR BEC = CC 10A Servo = HiTec 7954sh TX = Spektrum DX4S RX = Spektrum SR410 4ch Issue: I've double and triple checked everything for wiring errors, Everything checks out All Reds going to Positive, All Blacks going to Negative, all soldering connections are good and everything plugged in correctly to the Receiver. ESC Red wire disconnected and isolated for BEC use. I am fully able to use forward and reverse, and steering, and speed controller modes have been manually programmed and calibrated. However, I have to reverse my Steering and Throttle channels on my transmitter. Normally This would not be too much of an issue, but the ESC has one particular reversing mode that is supposed to make it so you can't go immediately from throttle to reverse. you have to leave the throttle at neutral for a second first. However for me it is backwards. I can go from throttle to reverse immediately, but now I have to wait a second before I can go forward again. This is a result of the Channel needing to be reversed on the transmitter. My question is WHY do I have to have my channels reversed to get proper control when EVERYTHING is wired correctly? Also, The ESC has a power switch, but the Receiver and Servo get power whenever the battery is plugged in regardless of the switch position on the ESC. I assume this is because of the BEC? Is this normal? and can I add a switch for this as well? Last edited by tomvaillencourt; 07-10-2015 at 04:21 AM. |
07-10-2015, 06:37 AM | #2 |
| Re: Help with DX4s and FXR?
Did you follow the directions when calibrating the ESC? Some brands (I know HobbyWing is an example) require you to reverse the throttle channel on your transmitter before calibrating the ESC.
07-10-2015, 08:55 AM | #3 |
| Re: Help with DX4s and FXR? I followed a video tutorial published by Tekin. I actually tried to calibrate it with the channels reversed first and also with the channels normal first. each way the result was the throttle and steering would only act correct with the channels reversed on the transmitter. Funny thing is when I put the channels in the normal position before calibrating, it will only calibrate throttle when I push forward and will only calibrate the brake when I pull the trigger. I think its a transmitter or receiver issue. The ESC is behaving normally.
07-10-2015, 09:00 AM | #4 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
set the ESC the way you want, and reverse the motor lead for the right rotation...
07-10-2015, 10:25 AM | #5 |
| Re: Help with DX4s and FXR? |
07-10-2015, 10:26 AM | #6 | |
| Re: Help with DX4s and FXR? Quote:
On a side note, Iv'e been thinking about it and I think the reason for the motor turning the "wrong way" is because of the direction in which it is installed within the truck itself. In both my new builds the motors are positioned with the terminals forward and the pinion pointing rearward. This would result in turning the drivetrain in the opposite direction. I'll just make sure to reverse the poles on my second motor when wiring it up. Thanks for the help guys! | |
07-11-2015, 11:11 PM | #7 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
I've run the same radio/ESC combo on several rig over the past few years. Your steering servo direction has no effect at all on the ESC calibration. the signal goes directly from the radio, to the receiver, to the servo. Nothing to consider there. I wish I could assist you with the throttle calibration, but it seems there's either an invisible glitch in the system or something's been overlooked. I've driven myself crazy tearing things apart and reassembling for days trying to find the source of a problem, only to realize it was one of these two things. I had a similar issue, very briefly, a while back when I had the motor wires on my ESC reversed. My eyesight is kind of crappy and I got the tiny +/- symbols on the ESC confused. Very happy I didn't do it on the battery side! |
07-12-2015, 12:12 AM | #8 | |
Quarry Creeper Join Date: Sep 2013 Location: post falls
They're talking about the throttle channel being reversed to calibrate the esc not steering. Also it's not the throttle calibration that's the issue it's that the Trans is spun, making it necessary to have reverse rotation compared to normal, like for a wraith. Quote:
07-12-2015, 07:01 PM | #9 |
07-13-2015, 02:54 AM | #10 |
| Re: Help with DX4s and FXR? He did specifically address steering in a few spots. Thought I'd offer help on that.
11-21-2015, 05:49 AM | #11 |
Help with DX4s and FXR? - Similar Threads | ||||
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
