09-06-2015, 12:45 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Canada
| Sensored brushless or waterproof sensorless 4 pole.
I narrowed my options down to the two above for my wraith. I don't run through a lot of water but it has come up on occasion. Are the sensored motors toast if they come in contact with water? I've watched videos on how to waterproof but I really don't want to be taking things apart if I don't have to. Sent from my LG-D852 using Tapatalk |
09-06-2015, 02:39 PM | #2 |
| Re: Sensored brushless or waterproof sensorless 4 pole.
For a sensored motor, you'd at least want to treat the board with something. As well as doing something for the sensor wire connection. Typically if it gets real wet you'll lose rotor sensor at the motor until it dries out a bit. More worry should be paid to the controller imo. |
09-06-2015, 03:11 PM | #3 | |
| Re: Sensored brushless or waterproof sensorless 4 pole. Quote:
Sent from my LG-D852 using Tapatalk | |
09-06-2015, 03:12 PM | #4 |
| Re: Sensored brushless or waterproof sensorless 4 pole. |
09-06-2015, 03:16 PM | #5 | |
Is the motor board easy to treat? If the motor gets wet is it ruined or will it be fine when it dries out? Sent from my LG-D852 using Tapatalk | |
09-06-2015, 03:20 PM | #6 | |
None of my motors have been ruined from being wet after treating. | |
09-06-2015, 03:52 PM | #7 | |
What do you use for coating? Does plasti dip work? Sent from my LG-D852 using Tapatalk | |
09-06-2015, 04:29 PM | #8 |
09-06-2015, 04:35 PM | #9 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
this is the one you want: http://www.amazon.com/gp/product/B004SPJOKK I used that in my MMP ESC and in the receiver and ROC412 motor and no problems yet, for the sensor plug i used shoegoo and works great |
09-06-2015, 05:23 PM | #10 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
09-06-2015, 05:42 PM | #11 | ||
Quote: Great info thanks | ||
09-06-2015, 05:43 PM | #12 |
If the waterproofing is so easy why don't the motors come water proofed?
09-06-2015, 05:53 PM | #13 |
Maybe because is a slow and tedious work
09-06-2015, 07:20 PM | #14 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
Holmes Hobbies offers their new BL motors waterproofed as an option, but it's really easy to DIY with conformal coating.
09-30-2015, 07:43 AM | #15 |
Hey guys just thought of something and i'm wondering if it will work. What if I go with a sensorless wp set and adjust the throttle curve on the tx to be really low at the start. Will that allow some basic crawling? |
09-30-2015, 08:39 AM | #16 |
sensorless startup won't allow any sort of real crawl. You have a crawler, don't screw yourself out of the one thing it should do well.
09-30-2015, 12:02 PM | #17 |
| Re: Sensored brushless or waterproof sensorless 4 pole. Thanks, I have an SCX10 that is exclusively for crawling. I also have a Slash 4x4 vxl that's built for speed. I'm looking for a mix on the wraith. I understand that the sensored setup is the way to go but I need to make sure that I'm able to waterproof as well.
09-30-2015, 07:05 PM | #18 | |
Just buy the Holmes Puller Pro from Holmes directly and let them waterproof it for you (they only charge $10 to do it). You'll get a great motor that crawls very well and has plenty of kick, not have to fuss with waterproofing it yourself, and not have to worry that the manufacturer will refuse to stand behind the product after finding out you waterproofed it. | |
Sensored brushless or waterproof sensorless 4 pole. - Similar Threads | ||||
Sensored vs sensorless 4 pole brush less for rock racing and crawling | gfmucci | Electronics | 8 | 05-25-2015 07:10 AM |
need advise, sensorless 550 2-pole 3300kv or sensored 540 4-pole 3300kv | Steelfish | Electronics | 20 | 06-21-2013 10:20 PM |
sensorless vs. sensored brushless motors | kalin96 | Newbie General | 6 | 06-05-2009 11:20 AM |
