09-26-2016, 07:45 PM | #301 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 Quote:
09-26-2016, 08:46 PM | #302 |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 |
09-26-2016, 09:10 PM | #303 |
The discharge rate is fairly linear at the kind of load you would see from a single servo. Unless you ran a 400mAh battery or something equally tiny, you would probably never get under 8v. I don't believe I've ever heard anybody recommend running a separate battery just for the servo. |
09-26-2016, 09:33 PM | #304 |
09-26-2016, 09:56 PM | #305 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
If you decide to use a BEC, John is recommending to set it at 7.4v because under load they will spike 300-400 mV or even more if stressed. He sent me this chart from an oscilloscope measuring the output of a BEC with a light load. Each division is 50 mV so you can see how much it oscillates between baseline and around +200 mV. The BEC in my Wromber died this weekend and I just got a new Promodeler servo so I'm going to give the dedicated battery a try. At the very least I won't have to worry about burning up another BEC. AFAIK, the airplane guys do use a battery separate from the motor batteries to run the servos. A small LiPo is way cheaper than a new BEC anyhow. I figure if it's good enough for them, why not give it a go? |
09-27-2016, 07:50 AM | #306 | |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
09-27-2016, 09:19 AM | #307 | |
09-27-2016, 10:12 AM | #308 | |
Quarry Creeper Join Date: Oct 2014 Location: East
I would argue the voltage sag from a good high discharge main pack driving a quality BEC under load, would be measurably better than the sag from a low discharge receiver pack battery, under load. A low discharge pack has a higher source impedance. The higher the impedance, the more the drop at the battery and not across the load. ...just thinking about it. | |
09-27-2016, 10:24 AM | #309 |
I don't have a small enough 2s to wire up with my Pico, or I would. The only mini battery I have on hand is 3s. Might give it shot with a 5000mAh just to see.
09-27-2016, 10:45 AM | #310 |
People still use 2s? Huh, who knew? |
09-28-2016, 08:27 AM | #311 | |
09-28-2016, 08:54 AM | #312 |
That's not powering the servo directly, you'll just be setting it up like every nitro out there. I'd go this way, nothing to interfere. As long as the servo can take 8.4v. |
09-28-2016, 11:56 AM | #313 |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 I'm planning to set it up basically like this, though I'd probably call what you have listed as "Receiver Pack" a Servo Pack as it is bypassing powering the receiver. My receiver can't handle the voltage of 2S so that will have to be powered off the ESC's BEC. I'm planning to use the holmes receiver bypass which does have a shared ground that isn't noted in your diagram. Like I said before I'm a newbie at this, so let me know if this plan isn't sound.
09-28-2016, 01:04 PM | #314 |
Run this servo at 7.4 not 8.4 HANG UP AND DRIVE ! |
09-28-2016, 01:10 PM | #315 |
09-28-2016, 01:23 PM | #316 | |
Or run a 3s through a BEC at 7.4v and stay at a constant voltage. Give or take a few millivolt ripple. I'll take the ripple. | |
09-28-2016, 01:44 PM | #317 |
I've been running mine at 7.5 volts for their entire life so there! |
09-28-2016, 01:53 PM | #318 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
This is one of the reasons for a bec, to have constant power. Air plane guys run multiple servos, so that's why they run a separate battery. Plus if a bec was to fail, I would rather have it happen on the ground, in a crawler, and not up in the air. | |
09-28-2016, 04:00 PM | #319 |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 John recommended a 2S lipo fully charged to 8.4V. If using a BEC, he recommended a 7.4V setting for the BEC.
09-30-2016, 10:03 AM | #320 |
Pebble Pounder Join Date: Nov 2005 Location: south jersey
I replaced a hi-tec7955 with this servo. I ran my hitec with my bec set at 8v. From what I'm reading I should turn it down to 7.4v? And, sorry to hijack but I recommended this wiring setup to a friend with a servo capable of running 8.4v the only difference was instead of a separate battery he ran the red/black to the main battery. As soon as he turned the truck on, the servo went full left and smoked before he could unplug it. Now I'm kinda leery of running a setup like this myself. Thoughts? |
ProModeler Servo: 420oz, billet case, o-ringed, $79 - Similar Threads | ||||
Billet Motorola Droid Razr Case | JFAB | Vendors Miscellaneous | 2 | 01-14-2013 08:24 PM |
Angry Apple Ipod billet case | motoworx | Vendors Miscellaneous | 31 | 08-15-2012 06:12 PM |
metal gears , billet case , coreless motor servo CHEAP | BL-4x4 | Electronics | 2 | 01-04-2012 09:21 PM |
