09-30-2016, 10:36 AM | #321 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 Quote:
Power and ground to power and ground, signal to the RX. Done. | |
09-30-2016, 10:37 AM | #322 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
7.4 to be safe. According to John, the S420 will fail catastrophically at about 9.2v. You could go up to 8.0 on your BEC but your safety window for BEC power spikes shrinks accordingly. If your friend had a 2s receiver pack and wired it correctly, everything should have been fine. What type of servo was it? I've smoked Hitecs twice at initial power-up which were previously working fine. Same symptom too - hard turn to one side and magic smoke. This is how I'm re-wiring my Wromber. I had John take a look and he gave it his approval. The main point is to isolate the inductive loads (motors, lights, winches) from the receiver and servo(s). EDIT - I had to add a ground from the Rx to the ESC, it would not arm without it. Last edited by mikebecher; 10-10-2016 at 03:48 PM. |
09-30-2016, 10:49 AM | #323 |
Pebble Pounder Join Date: Nov 2005 Location: south jersey
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 |
09-30-2016, 11:56 AM | #324 |
Was he on 2S or 3S LiPo? Fully charged?
10-06-2016, 09:50 PM | #325 | |
10-06-2016, 10:51 PM | #326 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
I had no idea John @ ProModeler was here in FL let alone in Orlando. I'm in palm beach, but will be in Orlando at the end of the month. Is there a physical location I can pick up a servo or is it only available on the website? The rain is just now starting to pick up. Hopefully I'll still have power for a long while |
10-07-2016, 05:17 AM | #327 |
Stay safe John ! And spoo76 ! HANG UP AND DRIVE ! Last edited by mikemcE; 10-07-2016 at 06:26 AM. |
10-07-2016, 06:23 PM | #328 |
Newbie Join Date: Sep 2016 Location: Texas
is there any servo fade after longer hard run time or centering issues?
10-07-2016, 07:54 PM | #329 |
I haven't had any HANG UP AND DRIVE ! |
10-07-2016, 10:43 PM | #330 |
cool, i think whats got me interested in it other than the bang for buck, is that the construction of the servo. The case and gears look extremely durable.
10-10-2016, 11:05 AM | #331 |
Ordered one of these this am. We'll see if it lives up to its supposed rep or not pretty soon.
10-10-2016, 11:36 AM | #332 |
I might have to pick one of these up. I bought a RC Gear Shop DHV300 Ultra Torque Digital Servo for my Bomber build and it's sloppy as hell. I don't know if it came like that or if it couldn't withstand the 4 batteries of use.
10-10-2016, 11:45 AM | #333 |
RCC Addict Join Date: Aug 2005 Location: SoCal
10-10-2016, 11:56 AM | #334 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
I slapped mine on the SCX10 last night. The truck won't be running for a bit but I think this servo has the best appearance I've seen that the pictures don't do it justice. I wear my head lamp when wrenching and I can't even look at the thing because it just blinds me until I look away.
10-10-2016, 01:57 PM | #335 |
10-10-2016, 02:01 PM | #336 | |
The Vanquish one from RPP Hobbies is cheap and does wonders, because the stock plastic will flex under strain, especially with more than double the wimpy Tactic servo's torque rating... Vanquish Products AR60 Axle Servo Mount Black Anodized | |
10-10-2016, 02:16 PM | #337 | |
The servo output shaft itself rocks back and forth a bunch. I should contact Tower and see if they'll stand good for it. | |
10-10-2016, 02:34 PM | #338 | |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 Mebbe... the only top (ish) brands I haven't killed are futaba and holmes. Quote:
Directions? Wtf is there other than to center the radio before installing the arm then set end points? | |
10-10-2016, 03:28 PM | #339 |
Setting voltage per specs, not what works on all the others , center and ep as stated HANG UP AND DRIVE ! |
10-10-2016, 03:31 PM | #340 |
Bec is already at 7.4 and the servo is rated for 8.4 exactly as bluebird.
ProModeler Servo: 420oz, billet case, o-ringed, $79 - Similar Threads | ||||
Billet Motorola Droid Razr Case | JFAB | Vendors Miscellaneous | 2 | 01-14-2013 08:24 PM |
Angry Apple Ipod billet case | motoworx | Vendors Miscellaneous | 31 | 08-15-2012 06:12 PM |
metal gears , billet case , coreless motor servo CHEAP | BL-4x4 | Electronics | 2 | 01-04-2012 09:21 PM |
