10-07-2015, 11:07 AM | #1 |
Newbie Join Date: Oct 2009 Location: sweden
| TQ4 Problem with winch
I have been using a 4ch 27mhz traxxas remote for a while and now i have upgraded to a 2.4ghz tq4. and now to the funny thing , the winch did work properly with all 3 ways when i used 27mhz remote . But with the new 2.4ghz its only have forward and reverse , the neutral position have disappeared . I hope you guys understand my SWEnglish , or else ask |
10-07-2015, 11:22 AM | #2 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Re: TQ4 Problem with winch
i don't know about the original 27MHz radios but on the 2.4GHz radio it doesn't have a true 3-position switch in it's stock config. it has the 2-position by the thumb and the other switch next to the wheel is actual 2 separate 2-position switches that are used for things like controlling the locking diffs in a summit. you could get a 2-position winch controller from heyok here on the forum. otherwise you will need to modify your tx. i did it for my tq4 2.4GHz radio. pretty easy. the 2-position switch near your thumb is actually wired to be a 3-position switch already. what you have to do is open up the radio, replace the existing 2-position switch with a 3-position switch (a little wire soldering and getting a switch to fit in the hole) and you are all set. i believe there is a thread somewhere out there on this. |
10-07-2015, 07:42 PM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Yep, jebster nailed it, the switch on the 2.4GHz radio aren't center off, I found the same thing. Theres some pics of how I changed mine on thread my Wraith build, just swapped in a 3pos toggle switch for the 2pos rocker. |
10-09-2015, 08:47 AM | #4 |
Thanks for the help,did take the switch from my old 4ch 27mhz radio and mounted it on the other en rerouted the cables . Thanks for the help guys! |
10-09-2015, 10:27 AM | #5 |
Rock Stacker Join Date: Jun 2014 Location: myrtle beach
I see u fixed your issue already, but you can also simply take the three wires leading to the red rocker swith by the thumb and switch them with the 3 wires on the 3 position switch on top and bam there ya go no adding switches or anything and u have a 3 position channel on top now and the red thumb switch still works too only thing that changes is what channel works with each switch channel 3 was the red switch and channels 4 and 5 were the top switch. Now channel 3 is on top and the red switch works channel 4. Hope that helps
TQ4 Problem with winch - Similar Threads | ||||
RC4wd winch + TQ4. chatter | frizzen | Electronics | 9 | 07-02-2012 10:10 PM |
tq4 and rc4wd winch??????????help | Kentuckcrawlers | Axial SCX-10 | 3 | 10-06-2010 09:20 PM |
TQ4 with 3 racing winch | bjs1785 | Electronics | 1 | 08-19-2010 04:06 AM |
using TQ4 with 3racing winch | rhothar | Electronics | 9 | 02-12-2010 11:41 AM |
TQ4 and 3Racing winch will they work together? | EARRNHARDT3 | Electronics | 1 | 10-25-2009 07:40 PM |
