11-24-2015, 08:21 AM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
| Why only 1 BEC?
Noobie question... Why is it that when you run an external BEC (or 2 ESC for Dual motors) that one ESC BEC has to be disabled? Wouldn't the 2 BECs working together provide MORE power?
11-24-2015, 08:24 AM | #2 |
| Re: Why only 1 BEC?
Generally, only the steering servo runs off the BEC. If you are running 2 steering servos for 4ws, you'd want either 2 10 Amp BEC's or 1 Castle Pro 20 Amp BEC. |
11-24-2015, 08:52 AM | #3 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Why only 1 BEC?
Also, the esc bec and a CC bec are generally providing different voltages. One will fry the other if the red wire isn't pulled.
11-24-2015, 11:03 AM | #4 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
| Re: Why only 1 BEC?
Also people usually run higher volts to their servo but the radio usually can't handle higher voltages reliably. So maybe 6+ to servo, while the radio gets 4.8V usually.
11-25-2015, 12:07 AM | #5 |
| Re: Why only 1 BEC?
To sum the previous answers up:
Why only 1 BEC? - Similar Threads | ||||
BEC | Castle Creations CC Bec 10A 6S Switching Regulator | le varan | Axial Yeti | 8 | 06-02-2015 12:08 PM |
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
