12-06-2015, 06:57 AM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Westport Island
| MMP with red and yellow led's on steady
Howdy, I've yet to find what this combo means. Spectrum RX, MMP on 3s. I have zeroed all trim, end points, ect, calibrated the esc per the instructions, rebound the system and continue to get a solid red and yellow, I even tried a different RX. When applying forward they both go out,the green flashes up until wot then stays on steady, during reverse both go out except the red glows dim. Any thoughts? Update: this scenario is only whens the sensor wire is plugged in....... Ive tried a different motor, different RX, different TX, different 3s, different wire. Sent from my Jitterbug Last edited by skybolt; 12-06-2015 at 08:16 AM. |
07-31-2016, 10:48 PM | #2 |
Newbie Join Date: Aug 2015 Location: taiwan
| Re: MMP with red and yellow led's on steady
Sorry to revive a year old thread but did you ever solve this problem. I'm having the same issue.
07-31-2016, 11:37 PM | #3 |
Quarry Creeper Join Date: Aug 2014 Location: sacramento
Your running your MMp with a brushless motor make sure it doesn't have the 1.51 software update there's bug that causes this issue, Just hook it up to your castle link and see what software your running if it's 1.51 just flash it back one I think 1.46 or something. Hope that helps |
08-01-2016, 06:11 AM | #4 |
What he said! ^^
08-01-2016, 11:39 PM | #5 |
Righteous! Thanks guys. Worked like a charm. Now if I can figure out why CHEAT mode only advances the timing in reverse I'd be golden. If any one following this thread is curious about my situation let me know and I will share, I dont want to start a thread on here as its related to on road.
MMP with red and yellow led's on steady - Similar Threads | ||||
Yellow Honcho and Red Jeep Trailing | téosrc | Scale Videos! | 2 | 10-07-2013 08:17 AM |
MMP Yellow light blinking and won't stop!! | Twisted Nuts | Electronics | 8 | 06-03-2010 11:19 AM |
Goat, Red/Green LED's Solid | AC-130 | Electronics | 9 | 10-12-2009 04:08 PM |
Finally MY LED's ARE WORKING!!! over 26 LED's | 4x4Crawler4LIFE | Scale Videos! | 11 | 07-28-2009 09:07 PM |
