02-19-2016, 02:29 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: SB
| Hay Ok no brainer BEC Help
Hello, Is anyone running a Hay Ok no brainer BEC? It says it is adjustable but I can't find anywear to adjust it or what your setting is. Wanting 6V but their is no way to tell are adjust, help please.. no brainer I guess I'm pretty lame lol Last edited by desertdude; 02-19-2016 at 02:40 PM. |
02-19-2016, 03:37 PM | #2 |
| Re: Hay Ok no brainer BEC Help
this one ?... do you have the 10 turn pot adjustment control ? if so... you need a voltmeter to check the voltage output reading, at the RX and Servo plugs, as the pot is turned. Yes the battery needs be hooked up. But don't connect the outputs to the RX or Servo until the voltage is determined and set. Voltmeter's can be purchased inexpensively if ya need one. I bought a low buck voltmeter at Harbor Freight. Maybe $ 3.00 spent. Not spectacular quality... but gets it done. I don't use the Hey OK nb'r BEC and instead utilize a 10a CCBEC adjusting voltage with the CC's link connected USB with my laptop. it's not rocket science regardless. If you don't have the 10 position control unit and a voltmeter... then I have no idea what you have going !? btw... it's Hey OK... not Hay OK Last edited by TacoCrawler; 02-19-2016 at 03:43 PM. |
02-19-2016, 04:36 PM | #3 |
It does have a pot adjustment but it looks like I need to cut the heat shrink to get to it. Gonna send it back and get a CC. |
02-19-2016, 04:44 PM | #4 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
I have been using a HeyOK BEC for about 3 years now. I did run into one problem. I had ground loop issues and ended up lifting the ground (black wire) that goes to the receiver plug. Worked fine after that. Jerry
02-19-2016, 04:49 PM | #5 |
| Re: Hay Ok no brainer BEC Help Was yours preset for 6V? Sad to say I don't no how to use a voltmeter
02-19-2016, 05:27 PM | #6 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
The website says preset to 6v. https://www.freewebstore.org/HeyOK-P...2_8041236.aspx |
02-19-2016, 05:47 PM | #7 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Mine was set at 6V and I changed it to 7.4. |
02-19-2016, 06:18 PM | #8 |
Thanks guys |
02-19-2016, 08:29 PM | #9 |
| Re: Hay Ok no brainer BEC Help |
02-19-2016, 09:07 PM | #10 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
I have and use the No Brainer BEC's but mine are the non adjustable ones, there set at 6volts I have no problems with them |
02-19-2016, 09:32 PM | #11 |
02-20-2016, 06:25 AM | #12 |
It sounds like you guys have this handled. Thanks! Yes, I preset them to six volts unless you ask for another voltage when you order it. The description on adjusting the voltage was pretty much perfect. Thanks again! First I had heard about a ground loop problem. Glad you were able to work out a solution. Al |
10-27-2016, 08:22 PM | #13 |
Quarry Creeper Join Date: Aug 2016 Location: Christiansburg
Disregard
Hay Ok no brainer BEC Help - Similar Threads | ||||
No Brainer BEC | heyok | Vendors Electronics | 93 | 03-12-2019 08:37 AM |
HeyOK No Brainer BEC | RABIDFOX | Electronics | 4 | 01-18-2015 04:36 AM |
no brainer bec | 503dave | Electronics | 4 | 02-02-2014 11:03 AM |
