Thread: help wiring
Old 02-29-2016, 06:43 AM   #1
Default help wiring
i knoe its messy but can anyone tell me if this will work? im running rear steering, a shift servo, and a light bar so this seemed like the best way to wire everything? or will it just catch fire when i plug the battery in
microcrawlers is offline   Reply With Quote
Old 02-29-2016, 09:44 AM   #2
mrG
Default Re: help wiring
It'll work just fine
Love the art work btw
mrG is offline   Reply With Quote
Old 02-29-2016, 09:53 AM   #3
Agree with mrG. I messed up a Hitec 7950 by trying to use the signal wire to the receiver without the ground.
deerco is offline   Reply With Quote
Old 02-29-2016, 12:27 PM   #4
cool thanks
i am planning on using the holmes rx bypass adapter and holmes bypass adapted with aux output and thats how i learned floating ground is a no no
if my lightbar takes 7.4v what should is it ok to run the bec at 5.1 or 6v or will that make the light too dim? ill post up what servos im using this afternoon because im not sure whether they can take only 6v or 7.4. i know the connectors are only rated for 5v. theyre both savox servos
thanks
help wiring - Similar Threads
Wiring Help b0wman Newbie General 2 05-25-2013 07:04 PM
wiring corvette crawle Electronics 1 08-13-2008 03:16 PM
Wiring CreamLad Electronics 3 05-13-2008 12:22 PM
Need help w/ wiring wal-mart crawler General Crawlers 1 08-20-2006 07:49 PM
