04-22-2016, 07:56 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Quad charger question
Looking for a good one. I did some searching and get more confused about chargers the more I read. With 2 Yeti XL running 2 batteries each I need more charger.
04-22-2016, 08:16 PM | #2 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: Quad charger question
You don't need a specific charger to charge 2 batteries at once. I use a Hobbyking ECO-10 200watt cheapo charger. It works, I'm not super fond of it, but it gets the job done. I use a parallel charging board. I can charge up to 6 batteries with this board. You hook up all your batteries, correctly, and select the amperage you need. Limited by your power supply / charger. The power supply needs to supply more than the max amps your charger pulls. The ECO-10 charger is a 10amp charger. My power supply is a 2zo-rc 47amp DC server PSU converted to power a DC charger. More than enough amperage. When selecting how many amps to use, you add up the mah of your batteries. If you have 2 4000mah batteries you can charge at 8amps for a 1c rating. 4amps for the 1 batt and 4 amps for the other. The equation is the same for other mah. 2200 + 2200 = 4.4amps You can charge higher than 1c ratings if your batteries can handle it. Instead of multiplying your mah rating by 1 use a different variable. If your batteries can charge at 5c rating use 5.. ETC. Hope that helps. EDIT: Chargers I like 10amp http://www.hobbyking.com/hobbyking/s...arehouse_.html 20amp Waiting for this to be in stock personally http://www.hobbyking.com/hobbyking/s...arehouse_.html Dual 20amp http://www.hobbyking.com/hobbyking/s...arehouse_.html Parallel charging board https://www.hobbyking.com/hobbyking/...dproduct=71349 Quad chargers: 4x6 amp http://www.hobbyking.com/hobbyking/s...arehouse_.html 4x20 amp http://www.hobbyking.com/hobbyking/s...arehouse_.html All these chargers I've listed are DC chargers. Meaning a seperate power supply is needed. Commonly found are converted PC powersupplies. Cheap, reliable, easy to find. Mine: http://www.2zo-rc.com/ HK: http://www.hobbyking.com/hobbyking/s...arehouse_.html http://www.hobbyking.com/hobbyking/s...arehouse_.html Last edited by robertjpjr; 04-22-2016 at 08:25 PM. |
04-22-2016, 08:24 PM | #3 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Lol, I know what you mean. I went with the dynamite prophet quad charger 4x100w. Its a beast, 100w/10 amp per channel. AC/DC. Dynamite RC: Prophet Sport Quad 4 X 100W AC/DC Charger: Dynamite (DYNC2050) |
04-22-2016, 08:48 PM | #4 |
Rock Stacker Join Date: Mar 2016 Location: in a van down by the river
| Re: Quad charger question |
04-22-2016, 08:54 PM | #5 |
Not really, your limited to charging the same battery's. I can charge 4 different battery, 4 different cells and 4 different amp ratings. Or I charge 4 of the same batterys as a parallel one does. That's the way to go. |
04-22-2016, 09:04 PM | #6 |
Quad charger question - Similar Threads | ||||
Charger Question | merlin3287 | Axial Wraith | 11 | 09-16-2012 11:35 AM |
Quad port charger | whoodie | Electronics | 6 | 01-30-2011 04:45 PM |
Charger Question. | tyerfryersc | General Crawlers | 3 | 05-29-2008 06:21 PM |
Charger question | '83 chevy | Electronics | 14 | 05-21-2007 08:30 PM |
