Thread: problem with my crawler
Old 04-06-2018, 06:11 PM   #1
Exclamation problem with my crawler
Hello I am new to the forums,But not the hobby. I have a axile deadbolt with stock electronics. and when it first turns on everything works perfectly fine but when i start driving it after 5 minuets or so the truck has extreme power loss. like no reverse power and like very slow forward throttle but if i turn it off and back on it works again for 5 minuets.
If you could help thank you
cjleh757 is offline   Reply With Quote
Old 04-06-2018, 08:03 PM   #2
Default Re: problem with my crawler
What battery are you using?
Sent from my Nexus 5 using Tapatalk
MasteroFlego is offline   Reply With Quote
Old 04-06-2018, 08:23 PM   #3
I tried all my batterys and it does the same thing. i think its the moter i am going to swap one in tonight
Old 04-06-2018, 10:01 PM   #4
Lipo or nicd batteries?
RiderZ is offline   Reply With Quote
Old 04-06-2018, 10:49 PM   #5
I use lipos. Its 1 am so i cant test anything right now but i put a 27 turn race motor from a pan car in it and it seemed to fix it from testing it in my garage and front yard. so ill give it a real crawling/mudding test tomorrow.
The new motor did not fix it
I took the jumper and took it out of lipo mode and it works fine its really weird
Old 04-07-2018, 08:21 AM   #6
esc overheating and cooling down?
Ninomaniac is offline   Reply With Quote
Old 04-07-2018, 09:19 AM   #7
The Axial AE-5 ESC is a piece of junk. Pick up a $16 wp-1060 from eBay (what I use), or better yet get a 1080 for $42. The latter has more settings and can power a medium-torque servo without an external BEC.
StomperCrawler is offline   Reply With Quote
Old 04-07-2018, 09:13 PM   #8
That's fine if you run NIMH. You said you run lipo, so you need to protect the battery from under-voltage damage using a $1 lipo alarm:
problem with my crawler - Similar Threads
rooster crawler problem Clod Killer Electronics 6 10-14-2010 06:07 PM
best crawler, money is not a problem sonat Newbie General 81 01-09-2010 03:43 PM
rooster crawler problem please help 4x4boy Electronics 3 02-22-2009 09:22 AM
Rooster Crawler problem jeepguy7891 Electronics 4 03-18-2008 11:49 AM
dx 6 or rooster crawler problem BUGGYBOY Electronics 8 09-24-2007 07:39 PM
