05-17-2017, 07:05 PM | #41 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| Re: HH Puller Pro 3500kv standard owners?
Can anyone post some settings for their MMX with this motor?
05-18-2017, 12:02 AM | #42 |
30% punch, high startup power, 30% drag, put a nice curve on the throttle and brake.
05-18-2017, 05:57 PM | #43 | |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: HH Puller Pro 3500kv standard owners? Quote:
This time I am thinking to run my heavy Wraith on 4s 2500mAh with your Puller Pro 2200kv brushless motor, paired with Robinson 9t pinion and 56t spur gear. Any thoughts, and suggestions? Thank you | |
05-18-2017, 06:38 PM | #44 |
Use a 1/10 scale controller and no worries
05-19-2017, 08:23 PM | #45 |
Rock Stacker Join Date: Jul 2013 Location: North West CT
I just gotta say this: You guys are GROSSLY underselling the whole brushless thing! My brother just put a Puller 3500kv with the Holmes ESC in his 2-speed Bomber and HOLY SH!T. On 3S it is almost uncontrollable! The tires balloon and send 20ft gravel rooster tails. I was blown away. We actually put a 2s back in it and then cut the throttle down to 60% to go crawling. If I had an extra $300 burning a hole in my pocket I'd have ordered a brushless setup from my phone on the trail! lol. Why do I keep getting into new and expensive hobbies!?
05-27-2017, 04:57 PM | #46 |
Question for JRH. Running with a BLE, went out yesterday on the rocks, new servo , had a thermal issue..... first time. esc showed thermal stopped running, checked temp later, motor 110, esc 120. I rarely see 105 on motor/110 esc. I messed with the expo on brake setting, way up(80%) as I'm getting downhill rolling. Would this excessive curve cause my heat issue? I thought more braking equals more heat ? Hang up and Drive Last edited by mikemcE; 05-27-2017 at 05:29 PM. |
06-15-2017, 06:26 AM | #47 | |
Will try 5 or 6S next time on my Puller Pro 540 2200kv | |
12-26-2017, 08:23 PM | #48 |
Newbie Join Date: Dec 2017 Location: PHX
For people running the HH ST 3500kv, I don't see an option for 5mm shaft, are you guys using a 16T 1/8” gear then?
12-26-2017, 09:28 PM | #49 |
Yes.... 1/8th inch or 3mm...
12-27-2017, 08:45 AM | #50 |
Thanks, I wasn't sure if people opt for the 5mm shaft or just used a 3mm pinion. Sorry, still learning about the new era of electric motors.
12-27-2017, 07:30 PM | #51 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Most, if not all 540 BL motors use 3mm. And most, if not all 550 BL motors use 5mm shafts.
HH Puller Pro 3500kv standard owners? - Similar Threads | ||||
Does anyone know the wattage of the new Holmes Puller Pro BL 540 3500kv? | Angus_Beef | Electronics | 0 | 05-15-2015 04:50 PM |
