05-17-2016, 07:15 AM | #1 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| Connecting New ESC, New Motor, and New Servo...
I am a bit of a noob when it comes to this stuff, but know enough to be dangerous. Here is my new electronics suite for my Bomber: *Holmes Hobby Puller Pro 540 3500kv WP *Mamba Monster X *Promodeler Servo *Stock RX/TX *Castle Creations Quick Connect Duo I would like the capability to easily disconnect components. I would also like to have the 3rd channel control drag brake. What do I need to cleanly / properly connect all of this together? I am not afraid to solder, but my experience is limited to soldering deans connectors (and not all that well). Thanks! |
05-17-2016, 08:33 AM | #2 |
Pebble Pounder Join Date: Mar 2014 Location: Raleigh
| Re: Connecting New ESC, New Motor, and New Servo...
Use Deans for your battery/esc plug. Use 4mm bullets for motor connection. If you plan to take receiver and esc out you can use velcro, or just go with servo tape. Other than that, you're pretty standard setup. |
05-17-2016, 08:42 AM | #3 |
Does the motor come with bullets? If not how difficult is it to install them? I thought I read that mamba monster X is 6.5 bullets.
05-17-2016, 11:40 AM | #4 | |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Connecting New ESC, New Motor, and New Servo... Quote:
I don't think you'll be able to have the 3rd ch control drag brake - that's a setting in the esc. The only things that might need soldering are that motor-esc connection and /or the esc-battery connection. The rest of it should be plug n play. Last edited by QuesoDelDiablo; 05-17-2016 at 11:43 AM. | |
05-17-2016, 11:50 AM | #5 |
MMX has aux connection that can be programmed for drag brake control. The motor has 4mm bullets but esc has 6.5mm. Will need to solder on some 6.5mm bullets to motor. Answered my own questions. Thanks.
05-17-2016, 01:19 PM | #6 |
| Re: Connecting New ESC, New Motor, and New Servo... |
Connecting New ESC, New Motor, and New Servo... - Similar Threads | ||||
motor and esc and servo | crwler | Axial Wraith | 5 | 10-16-2012 08:17 PM |
motor/esc and servo help??? | russp | Electronics | 1 | 02-20-2011 06:28 PM |
upgrade servo or motor/esc? | el_Fernando | Losi Mini-Rock Crawler | 7 | 03-29-2010 09:30 PM |
