05-22-2016, 06:27 AM | #1 |
Pebble Pounder Join Date: Apr 2015 Location: Charleston
| SV3 Mounting Bracket
I'm running a Jevne Racing plate. I have a CC Sv3 ESC that I would like to keep in the front on the plate. I currently have it taped on but looking for other options. I've saw the RPM case, anyone have any suggestions other than the RPM? Sent from my iPhone using Tapatalk |
05-22-2016, 02:05 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
| Re: SV3 Mounting Bracket
I am looking for another option, also. The RPM would have been perfect, if it wasn't for those two switch mounts locations which made it look more bulky.
05-22-2016, 05:04 PM | #3 |
I simply use velcro to hold my BR/XL, Heyok winch controller, etc. Holds well to any plate/smooth surface and allows component removal/relocation, dependant on user's wants. If the bonding suface is cleaned (alcohol wipe) prior to adhesion seems to hold just fine and looks to offer some impact absorbtion as well. the CCBEC is adhered to the BR/XL's case using a dab of Gorilla glue... ^ only two screws that hold my upper alloy plate but seems to be staying put/holding up fine ~ e componenets really don't weigh much ~ Last edited by TacoCrawler; 05-22-2016 at 05:08 PM. |
05-24-2016, 11:17 PM | #4 |
Quarry Creeper Join Date: May 2008 Location: Out in the country
What TacoCrawler said is perfect. I concur 100% Another option, although a little more permanent but still removable is to use silicone servo tape. It, as well as the Velcro technique lets you place (whatever item). Just another option to consider... |
05-25-2016, 07:45 AM | #5 |
I think I'm going to go with the Velcro. Seems to fit my bill perfect. One question though. What about the switch? Sent from my iPhone using Tapatalk |
SV3 Mounting Bracket - Similar Threads | ||||
Bracket for mounting servo to Enroute axles | 4ruggy | EnRoute Berg | 5 | 05-03-2009 11:33 PM |
Easy clocked motor plate and mounting bracket | rockwerks | HPI Wheely King | 21 | 06-13-2007 07:32 AM |
Lower link and shock mounting bracket question | 4x4dodge | HPI Wheely King | 9 | 04-30-2007 10:28 PM |
