06-16-2016, 02:21 PM | #1 |
Newbie Join Date: May 2016 Location: Norway
| Tekin 1/8 RX8 Gen2 Brushless Sensored/Sensorless ESC
What kind of plugs does this come with? Deans? Sent fra min SM-G930F via Tapatalk |
06-16-2016, 02:37 PM | #2 |
Quarry Creeper Join Date: Dec 2015 Location: United States
| Re: Tekin 1/8 RX8 Gen2 Brushless Sensored/Sensorless ESC
I don't think it has a connector, you have to buy and install your own.
06-16-2016, 03:35 PM | #3 |
According to towerhobbies it comes with Receiver Connector, Motor and Battery Wires, is that not all the cables i need? Do i have to get the "pins/connector" myself and solder them? Sorry for bad english Sent fra min SM-G930F via Tapatalk Last edited by TIshoel; 06-16-2016 at 03:37 PM. |
06-16-2016, 05:03 PM | #4 |
Your English is fine, a lot better than some Americans. You get all the wires you'll need and the connector to pug into the receiver, but you have to buy the power connector(s) to match your battery. |
06-16-2016, 06:20 PM | #5 |
Rock Stacker Join Date: May 2016 Location: USA
I don't recall either of my RX8 Gen2's coming w/battery wires, just the 3 motor wires. You have to solder everything, except the rx. If you want bullets between the esc/motor you'll need those too. It does come w/the hotwire adapter.
06-16-2016, 06:57 PM | #6 |
Should have been three pieces of wire (red, black and white came with mine) with enough length (about 12") to connect the battery and motor with a little of one color (white) left over. I think some assume they're to use each whole wire for the motor connection and buy the battery wire separate, and with some chassis layouts it may be necessary due to motor, battery and ESC placement.
06-16-2016, 07:53 PM | #7 | |
| Re: Tekin 1/8 RX8 Gen2 Brushless Sensored/Sensorless ESC Quote:
