06-18-2016, 07:30 PM | #1 |
Pebble Pounder Join Date: Sep 2011 Location: Between the thoughts of yesterday and the ideas of tomorrow
| DX4 R pro
Does anyone know if the radio has a reverse lock out feature or is it only on the esc? The reason I ask is because on two separate systems if i flick reverse it works but only for a second. Holding it does nothing. These systems work normal on other channels of the radio. Thank you
06-19-2016, 08:14 AM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: DX4 R pro
Is the radio calibrated to the esc on all the systems you are trying ? Do you have the esc set to forward/brake/reverse ? That would require a double tap on the trigger. Set to crawler reverse in the esc if possible, if you are using it in a crawler. |
06-19-2016, 01:17 PM | #3 |
| Re: DX4 R pro
The radio is calibrated to all systems. It did require me to set f/b/r but on that particular channel reverse will not work. on another channel it does. It is not for a crawler, so i might just have to reset the radio.
DX4 R pro - Similar Threads | ||||
Spektrum DX4 question | Blades | Electronics | 8 | 08-25-2015 08:47 PM |
Spectrum dx4 series radio. | onecool54@yahoo | Electronics | 7 | 04-15-2014 02:32 PM |
4pl vs 4pk vs dx4 | Diablo666 | Electronics | 15 | 09-19-2013 10:09 PM |
Dx4 | BigGuyJT | Electronics | 15 | 02-28-2013 09:47 PM |
