Thread: Power switch for sidewinder3
Old 06-30-2016, 08:18 PM   #1
Default Power switch for sidewinder3
So was out crawling last weekend. Lost power and found a lead came out of the power switch for the sidewinder3. To get thru the day I twisted the wires together. Do they make a replacement waterproof switch or should I just solder these wires together?
Espo is offline   Reply With Quote
Old 06-30-2016, 08:37 PM   #2
I joined the Band!
Default Re: Power switch for sidewinder3
Solder it man.. Who uses power switches anyways?
Capwn is offline   Reply With Quote
Old 06-30-2016, 08:37 PM   #3
Just solder the wires together. All of my rigs have the switch cut off and I can't see any benefits of replacing the switch over removing the failure point (the switch and attending wires)...
micro racer is offline   Reply With Quote
Old 07-01-2016, 05:13 AM   #4
Ok, I'm new to the hobby and it just feels right to have to have a switch. But like you said, it bit me on a nice trail run, kept cutting off till we figured out it was the wire pulling out of the switch.
Old 07-01-2016, 06:40 AM   #5
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
That is typically the first problem a new rig has. I don't have switches on anything, plug it in and it's on.
JohnRobHolmes is offline   Reply With Quote
Old 07-01-2016, 07:08 AM   #6
A lot of us, everything I have still has the switch attached to it and I won't buy an ESC without one.
Soldat Vaillant is offline   Reply With Quote
Old 07-01-2016, 07:14 AM   #7
And I will never make an esc with one, lol. You must never get wet, or maybe you are OK with the occasional replacement of the switch?
Seems if they don't fail from corrosion , they rattle apart in my rigs. 100% failure rate for me in crawlers.
Old 07-01-2016, 09:04 AM   #8
Yup, I've never had a switch last more then a couple of runs before I have to bypass it. Now they just get cut offer before that rig even leaves the bench.
QuesoDelDiablo is offline   Reply With Quote
Old 07-01-2016, 10:45 AM   #9
Water proof switches are available or you can waterproof the one's that come with the ESC. I would think heyok could come up with something too. If you mount a switch to a solid object that's subjected to a lot of vibration/shock or let the switch bounce around unsecured they will "rattle apart". What you're doing amounts to abuse, not really the fault of the switches.
"a couple of runs"
And I thought "100% failure rate" was a stretch.
I've never had much trouble with RC switches, but I've been around while and had electronics experience before entering the RC hobby in the early 90's. So anything RC that was going to get wet got protected. This was mainly nitro powered cars, trucks and boats due to fuel spillage, exhaust oils and obviously water exposure with the boats.
Old 07-01-2016, 10:58 AM   #10
Natedog's Avatar
Cut the wires off, carefully open the case, solder it together at the circuit board.
Old 07-01-2016, 11:14 AM   #11
I always mount switches solidly to the chassis or ESC. No stretch about 100% failure rate of on/off switches in my crawlers, I wouldn't forgo the switches on a production ESC if it wasn't a very common problem. Every single ESC would fail that way until I started cutting them off ahead of time to avoid it. I've had a few switches fail in my go-fast rigs too.
Crawling IS abusive to parts. Anything that can rattle apart, will rattle apart. You have basically described any rock crawler with this statement: "If you mount a switch to a solid object that's subjected to a lot of vibration/shock or let the switch bounce around unsecured they will "rattle apart". What you're doing amounts to abuse, not really the fault of the switches." I agree it isn't the fault of the switches. My job is to fix the problem that crawling creates, which is done with highest success by complete removal of the first failure point.
I would also point out that everybody else in this thread has probably experienced the same issue and has recommended the same thing. It is not a rare problem, it is THE problem everybody runs into.
Old 07-01-2016, 12:08 PM   #12
B!tches run switches makes perfect sense in this company.
WHITE-TRASH is offline   Reply With Quote
Old 07-01-2016, 01:02 PM   #13
Then you should congratulate me on being the one, and only, person on this entire planet to avoid "THE problem everyone/everybody" else is plagued by.
Old 07-01-2016, 01:43 PM   #14
I joined the Band!
Or shame you for having a rig that's never seen so much as a speck of dust..
Can RC trucks be Mall Rated?
Old 07-01-2016, 02:17 PM   #15
arguing opinions is nothing but a waste of time and emotions.
as in all life there are drawbacks to just about everything but doing nothing is even worse.
soldat, you obviously believe in switches and are willing to spend the effort in maintaining them.
more power to you
others are comfortable not using the switch and are satisfied with that, more power to them
but right and wrong? that is judgmental and a waste of time
the only important thing is to have the transmitter powered up before the receiver gets any juice.
I can send you 4 switches I took of some sidewinders so you can have some spares.
cabron is offline   Reply With Quote
Old 07-01-2016, 02:26 PM   #16
I'm not kind to my vehicles, but I'm also not going run them over with a tank then bitch about a "failure" at any percentage.
Old 07-01-2016, 06:14 PM   #17
Originally Posted by cabron View Post
soldat, you obviously prefer to use switches and are willing to spend the effort in maintaining them.
I spend very little time/effort "maintaining" switches because, as mentioned earlier, "I've never had much trouble with RC switches".
There are reasons I won't own Castle or Castle based ESC's, their switches is one of those reasons. So I'll be declining your patronizing offer.
For the record, I'm not arguing anything is good/bad or right/wrong. I simply stated another point of view on a subject that's debated all over the RC related web then fielded a little sarcastic rambling from john and cap.
Old 07-01-2016, 09:37 PM   #18
I would honestly say it is a well deserved congratulations too!
New switches on castle mamba x line is much better. Probably wouldn't have as much trouble.
Old 07-01-2016, 10:11 PM   #19
I joined the Band!
Even my monster x got the axe.. A switch is just something that does exactly nothing, sitting there ready to fail at the worst possible time.
Old 07-01-2016, 11:00 PM   #20
...So I'll be declining your patronizing offer.
"To assume a tone of unjustified superiority; to talk down to; to treat condescendingly"
I talk opinion and you talk patronizing?
pot calling the kettle burnt?
Power switch for sidewinder3 - Similar Threads
Best way to stick a power switch down? Wehan Newbie General 33 02-06-2016 11:58 AM
Need a power switch...help! Nelstrodomous Electronics 2 06-11-2009 11:15 PM
Adding Power Switch maxxa87 Electronics 6 06-11-2009 08:42 PM
switch wiring for power, do u switch - or + toy4crawlin Electronics 3 09-09-2008 04:59 AM
power switch problem SlammedMini469 General Crawlers 14 05-13-2006 10:24 PM
