07-30-2016, 10:03 AM | #21 | |
| Re: HiTec 7980 in a Bomber? Quote:
07-30-2016, 10:47 AM | #22 | |
Rock Crawler Join Date: May 2013 Location: Dallas
Goodbye battery life though... I noticed a huge decrease in run time going from a 7955 to a 7950 in my C2 truck, I know something that makes that much torque is going to draw a lot of amps! | |
07-30-2016, 11:00 AM | #23 |
A big block uses more fuel? You don't say! |
08-03-2016, 05:53 AM | #24 |
I feel your pain burning through expensive servo's. I destroyed several hundred in servo's in my Wraith before stepping up to a 7980. While I couldn't get a 7954 to survive a single pack, and 7950's might go a couple monthes before the "amplifier" died (that's what my warranty slips from Hitec say), the 7980 has been flawless for over two years. It DOES NOT use the same "MK" plastic gear as the lesser 7900 series do. I've stripped out a couple Robitronic's clamping horns and the servo keeps on going. The only downsides to the 7980 are cost, making it fit in certain vehicles, and it is a smidge slower than a 7950. The upsides are it doesn't break and it doesn't care how bound up the truck is. It will either steer the tires or swing the back of the truck around. Overall it's the best money I've spent on any electronic device ever. Some of us are just way harder on equipment then others. Typically if something can be broke, I'll break it. That said, I put a Promoder 420oz/in V2 in my Bomber because it's what I had on hand. It's plenty fast, almost strong enough. After about fifteen hours the output has a bit of gear-lash slop, but it's hanging in there. I have another 7980 NIB for when it decides to crap out because I like to be prepared. The best way to destroy servos is to smash the horn into obstacles, so if you can tuck the servo in close to the axle so that the drag link is behind the tie rod you'll be doing yourself a favor. I don't have one, but everyone keeps telling me that Hitec's will last much longer in servo saverless crawlers if you use their programmer to open the deadband a little and actually use the overload protection. This will result in a quieter and cooler running servo which equals longer service life. |
08-09-2016, 04:13 PM | #25 |
Quarry Creeper Join Date: Dec 2005 Location: the first state
| Re: HiTec 7980 in a Bomber? |
08-09-2016, 04:46 PM | #26 | |
Rock Stacker Join Date: Jul 2015 Location: Fredneck
Trail on! | |
HiTec 7980 in a Bomber? - Similar Threads | ||||
HItec 7980 | lurchy | Electronics | 5 | 12-28-2012 06:51 AM |
Hitec 7980 | lurchy | Axial Wraith | 1 | 12-26-2012 08:36 PM |
Hitec 7980 help | crawlinghulls | Electronics | 3 | 12-22-2012 11:44 AM |
