08-07-2016, 05:51 PM | #1 |
Rock Stacker Join Date: Sep 2006 Location: Corning
| Winch install on bomber
So I'm wanting to install a winch on my bomber. Possibly one of the rc4wd ones but not set in stone on that. Been doing a lot of reading on how to wire it in and what not. Kinda more lost now then before I started. I have the tactic e channel controller, but am I correct that the reciever isn't going to put full battery voltage to the winch if hooked up that way? Put a winch on my kids wraith using the wireless controller and remote but wanted to try and run mine using the buttons on the controller already. Any help is appreciated |
08-08-2016, 11:30 AM | #2 |
| Re: Winch install on bomber
Maybe I can help. First though, I am not sure what this is: "tactic e channel controller" Maybe a link or a picture would help, but I assume it is the remote control transmitter that you have. The thing to find out is if there is a third channel and if it is a two or three position channel. Next you need to decide on a winch controller. To put full battery voltage to the winch, one of these winch controllers will work: These two are for a three position channel, but I can make them for a two position channel as well: 4 Amp Relay Output Winch Controller Or this one which is functionally the same, but takes up less space: Compact 4 amp Winch Controller If you want a key fob type remote, then this will work: Wireless Winch Controller Hope that helps! Al |
08-08-2016, 09:56 PM | #3 |
Sorry was suppose to say 3 channel tactic
Winch install on bomber - Similar Threads | ||||
Warn winch install | tigerhawk | Axial SCX-10 | 13 | 12-28-2014 11:59 AM |
SCX10 3Racing Winch Install. Check it out! | gregrob | Videos! | 0 | 11-14-2014 12:50 AM |
HOW TO: 3Racing winch install on an SCX10 2012 Rubicon. | 4WheelRC | Scale Accessories | 3 | 01-03-2014 03:52 PM |
winch install problem | kdizz07 | Newbie General | 9 | 07-28-2013 09:40 AM |
How to install switch for winch? | Norcal crawler | Electronics | 2 | 11-20-2007 09:53 PM |
