08-08-2016, 01:46 PM | #1 |
Newbie Join Date: Jul 2016 Location: Bluffdale
| Thunder AC6 Charger Decrease button Issue
My Thunder AC6 Charger has acting flawlessly for the last year until yesterday. When trying to decrease any selection, it sends me back to the previous screen instead of decreasing amps, cell voltages etc. My increase buttons works just fine. Example: I want to charge my pack at 4 amps, I went past the 4amps I wanted and then went to decrease the amps and it took me back to the previous screen instead of adjusting the amps. Has anyone ran into this. Is there a way to get the charger back to factory reset to see if that fixes the issue? I powered it down and tried again with same issue. Thanks, Rob |
08-09-2016, 09:20 PM | #2 |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: Thunder AC6 Charger Decrease button Issue
A lot of micro-controllers use a single input for several buttons, what they do is each is connected to a different resistor. My guess is something has caused the resistance to change - moisture, corrosion, bug, etc. That charger uses membrane buttons, so it's also possible the ribbon cable is damaged.
08-09-2016, 10:11 PM | #3 |
Thanks, I'll try to work around it for now if I don't see any red flags when I take a quick look inside, but looks like new charger may be coming soon.
Thunder AC6 Charger Decrease button Issue - Similar Threads | ||||
Venom pro charger vs. thunder ac6 charger | TrxSlash5 | Electronics | 7 | 06-30-2013 04:20 PM |
Thunder AC6 Charger (help) | Jeepster77 | Electronics | 17 | 03-02-2013 09:06 PM |
thunder ac6 charger help | throttlejock27 | Electronics | 7 | 06-10-2012 07:24 PM |
Thunder AC6 charger | hende | Electronics | 13 | 09-23-2010 05:59 PM |
